  • June 18, 2025, 08:00:10 AM
Author Topic: How to remove cylinder liner ?  (Read 1149 times)
Offline Rob Killick
« on: October 06, 2007, 12:09:25 PM »
Hi ,
I know this has been asked before , but I'm having difficulty removing a liner from a ST G21/.35 ...
The liner is seated properly in the crankcase , but when you look in the exhaust port , the liner and cast case ports are flush .
This poses the problem of trying to use a popsicle stick , or flat copper bar and the piston to raise the liner from the crankcase .
I have used an ultrasonic cleaner , with 170 deg F heat , to no avail , so now I have been soaking the assembly in a product called "Aerokroil" penetrating solution (good stuff) .
My last option is to try and tap it out from the bottom using a brass drift .
Any ideas ?
Rob Killick , MAAC 33300
Offline Tom Perry
Re: How to remove cylinder liner ?
« Reply #1 on: October 06, 2007, 12:47:37 PM »
Rob,
Try it from the inside with a brass washer or Popsicle stick.  Sometimes you can manipulate the end of a tooth brush or similar to pry from the inside through the back cover.  If you haven't done so already heating the case with a heat gun may help.
Good luck.   :)
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #2 on: October 06, 2007, 01:48:11 PM »
Hi ,
Any ideas ?
Rob  The  sleeves  are  pressed in, you must use heat the case to remove the sleeve, I hold the case with a vise grip pliers and heat the case, then push the sleeve out from the bottom with a stick, grab the top of the  sleeve  with a rag or gloved hand and just lift it out
Offline Rob Killick
« Reply #3 on: October 06, 2007, 04:45:29 PM »
Alrighty , then ,
I'll give it a go :)
Thanks Men
Rob
