  • June 21, 2025, 09:50:44 AM
Author Topic: Needle Setting on Fox .35 Stunt using ST NVA  (Read 1214 times)
Offline David Ruff
« on: April 26, 2015, 06:02:08 AM »
Installed the ST .51 NVA in a Fox .35 Stunt.  Just wondering how many turns open I should start with.
Thanks in advance.
Retired Army
Offline frank mccune
Re: Needle Setting on Fox .35 Stunt using ST NVA
« Reply #1 on: April 26, 2015, 07:04:24 AM »
    Hi Dave:
     Bring it to Hampden today after 14:00 for help or you may try 3-4 turns open and play it by ear.
        Frank McCune
Offline Robert Zambelli
« Reply #2 on: April 26, 2015, 07:35:52 PM »
Dave - I have tried that setup and had problems.
The ST spray bar is a larger diameter than the Fox and will restrict your intake.
Turn down the spray bar to .125 where it crosses the venturi.
Or, buy one from Randy Smith.
Offline bruce finley
« Reply #3 on: April 29, 2015, 10:59:40 AM »
could you drill the venturi instead?  and what size drill bit would that be?
Offline bob whitney
« Reply #4 on: April 29, 2015, 04:27:37 PM »
if u drill the venturi all the way through u will change the crank timing and it wont run the same ,Randys needle assby works great
if u have a drill press u can chuck the spray bar up and file it down on the part that is actually in the venturi. go slow and suport it while u file
rad racer
