  • June 20, 2025, 06:34:04 AM
Author Topic: Anybody running a B.G. ST51 P&L  (Read 4898 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: April 17, 2016, 04:32:44 PM »
Wondering if anyone has had a chance to install and run one of Brian's P&L in a ST51 yet? If so are you using the stock head?
Re: Anybody running a B.G. ST51 P&L
« Reply #1 on: April 18, 2016, 02:16:04 PM »
Milton has benched one, per the topic in the link below. Topic drift was fairly extreme, AKA "normal"!  LL~ Steve
http://stunthanger.com/smf/engine-set-up-tips/review-of-the-brian-turner-st-51-piston-liner-and-rod-set/
Offline John Tate
« Reply #2 on: April 18, 2016, 06:49:54 PM »
Bob.
I just flew my B.G. ST51 P&L. The head that came the P&L had the standard (small) combustion chamber. On the test stand, the engine was touchy on the needle. So I change the head to one of my opened up combustion chambers. I was able to dail in the needle much better with the opened up combustion chamber. I only did two flights. The first flight was a little on the lean side and second flight was a little rich. It will take me a few more flights to figure out what the perfect RPM should be. It will be different that the old ringed version.
Offline Brian Gardner
« Reply #3 on: April 18, 2016, 09:47:31 PM »
My head is slightly lower comp than the stock head, but still squish band, not a full hemi like we did for the 46 & 60. I just changed the chamber volume by the amount I used to shim the stock head by. That way we had the slightly lower comp but with an effective squish band still.
« Reply #4 on: April 19, 2016, 08:20:49 PM »
 LL~ LL~ LL~
Offline Andrew Tinsley
« Reply #5 on: April 20, 2016, 06:30:31 AM »
Brian's P/L set up cured my highly erratic running ST51 into a very good stunt motor. I have limited flying time on it. But it just gets better and better as it beds down.
Andrew.
BMFA Number 64862
Offline John Tate
« Reply #6 on: May 01, 2016, 09:55:26 PM »
I came in second in the Profile event at Huntersville, NC this weekend using the B.G. ST51 P&L. The engine ran very smooth and had no problems adjusting the needle for the changing condition there.
« Reply #7 on: May 30, 2016, 08:12:06 PM »
I haven't had much feedback, but I am told they are taking a fair few flights to fully settle in.
« Reply #8 on: May 30, 2016, 10:06:26 PM »
At least 1 had about 30 min  run time before it settled down, so don't worry about putting a little time on the P/S, by the way they run very well with the stock head, if needed add an additional shim
Offline Luiz Ribeiro
    • Ribeiro's Home Page
« Reply #9 on: May 31, 2016, 10:54:10 PM »
We assembled our set more or less two months ago in one almost new stock Chinese ST 51, that was only bench ran for a few times before installing the new BG ABC.
To install the new set, after taking out the old, and installing the new piston and rod in the crank, what was easy to do, we had to heat the case with a small  torch and freeze the new liner in the refrigerator before throwing it in the case. This way, it entered easily, but maybe this wasn’t the best choice to do the job, because when it will be necessary to disassemble the engine in the future, we can have difficulty to take it out. Another way was to grind/lap the internal part of the case or the external of the liner and install the liner without heating and freezing the parts. This would require much more work now, but maybe with less difficulty in the future.
Another thing is that the piston and liner, even before installing the set in the engine, were too tight with each other, but we choose, for obvious reasons, not to grind any of them and leave this job for the brake in sessions, on the bench.
We bench ran it with one Master Airscrew 12X5, nylon propeller, glow with 5% nitro and 22% oil 50 to 50. It always started very easy, but In the firsts runs didn’t pass 8500 rpm (four cycles), if we tried to pass this rotation, closing the needle, it heated and died. This was caused by the very tight fit between piston and liner. We changed the prop to one APC 13X4 Sport and introduced one more shim in the head. After almost 1 liter of fuel and many runs of 2 min it was hitting higher speeds. After 0.5 liter more it was hitting 10500 rpm in a very constant 2 cycles for 30 s. It wasn’t totally broken in, but we considered this enough to install in a plane.
We installed it in an ARF Pathfinder that my son (35 y) was using to train the F2B gamma maneuvers. The plane was with an O.S. 46 LA, before, but we were looking for a little more power and torque, and we got this with the substitution, using the same prop of the LA 46, a Master 12X5, nylon, and the same fuel that we used to bench run.
It always started very easily, in the first or second flip when cold and a little more flips when hot, with very constant and reliable runs with a good 4-2-4 if well carbureted. With this prop we were launching in a fast 4 C with 9200 rpm. It spends a little more fuel than the LA. We are using a 5 Oz, uniflow, pressurized tank for a little more than 6 ½ min flights. The muffler is a very light (28 g) T&L for ST 51.
Now we are with almost 50 flights with it in the plane, very reliable and strong in all gamma maneuvers. We recently changed the prop to a 12X6, nylon, MA. With this prop we are launching with a fast 4 C in 8400 rpm. Next step  will be to change to a wood 12X6 MA, more light than the firsts.
However, we think that the piston is still a little tighter than usual and don’t know if this wouldn’t force excessively the rod with the time or if this only means that the set will have a long duration life. The truth is that until now we are very happy with the set and engine.
Thanks to Brian. Luiz
« Last Edit: June 08, 2016, 12:39:14 AM by Luiz Ribeiro »
« Reply #10 on: June 01, 2016, 07:20:22 AM »
The OD of the liner was the average measurement taken from a number of sample engines both Italian and Chinese. They will be tight in some cases and perhaps a tad loose in others. We had the same approach with the ST46 and 60 with the same results. It's something that can't be avoided.
Luiz I thank you for the feedback.
« Reply #11 on: June 01, 2016, 07:03:55 PM »
A steel round bar machined to say 1 thou.  :-\ below reqd. diameter , and a bit of fine lapping paste should open the case bore straight easy enough , if the sucker overly tight . Slot 3/4 through along , for collapsing it .
