  • June 20, 2025, 07:20:42 AM
Author Topic: How to determine prop loads for 3 bladed props?  (Read 3785 times)
Offline frank mccune
« on: May 30, 2016, 07:01:37 AM »
     Hello:
     How does one determine the prop load of a 3 blade prop as compared to a 2 blade prop? I would like to try some 3 blade props but I have no idea as to which props to try.  For example, what is the equivalent 3 blade prop for a 10x6 2 blade prop etc.?
     In the past, I used the formula for a 2 blade prop as 2x diameter plus the pitch to determine then prop load.  How would I compensate for the third blade? Would I just add the pitch of the additional blade?
    Any suggestions?
        Tia,
        Frank McCune
Offline Chris Wilson
Re: How to determine prop loads for 3 bladed props?
« Reply #1 on: May 30, 2016, 04:57:21 PM »
http://www.controlchat.com/props-and-propellers/
Converting from a 2-blade to a 3-blade propeller
To convert from 2-blades to 3-blades you want to decrease the total blade area and increase your pitch. The general rule is to DECREASE propeller diameter by 1-2”,  and INCREASE by 1-2” the propeller pitch.  It is all right to keep the same pitch when you go from a 2-blade propeller to a 3-blade propeller, however don’t decrease pitch.
MAAA AUS 73427
« Reply #2 on: May 30, 2016, 06:00:37 PM »
        Hi Chris:
        Thanks for the information.  This may help me to determine what sizeps prop I will use.  I am looking for a bit of more ground clearance for the prop.
        The only prop that I have used is a 10x6 three blade prop on an OS FP .40 converted to Diesel via a DDD head.  Yes, it looks cool on my Zero fighter.
        Be well,
        Frank mcCune
« Reply #3 on: May 30, 2016, 07:12:59 PM »
       Hi Chris:
        Be well,
        Frank mcCune
Hi Frank,
                I know that a PAW 40 setup for stunt use prefers a two blade 11X7, so according to the formula a three blade 10X8/7 should be on the money.
Diesels don't run away like glows so the extra pitch won't overspeed the model.
MAAA AUS 73427
« Reply #4 on: May 30, 2016, 10:13:02 PM »
    Hello:
    Any suggestions?
       I am not sure what you mean by "prop load" in this context, and if you mean "how hard it is to turn" then the pitch part looks backwards. All else being equal, it's harder to turn a 5" pitch prop than it is a 6" pitch prop, because you have to turn the 5"  much faster to get the same airspeed, and/because it is less efficient. The 6" is harder to turn on the ground, but not in the air.
    Additionally, the usual concept for a 3-blade is to get more blade area without the detrimental effects of diameter, so in a sense the idea is to increase the load.
      A very general rule of thumb it ~10% less diameter for a 3-blade VS a 2 blade of a similar type. But you really do just have to experiment, because there is *far* more going on with props than the loading of the engine.
« Reply #5 on: May 31, 2016, 05:53:55 AM »
      Hello Brett et.al.:
      What I was mainly concerned about was placing a too large of a load on the engine in order to gain a bit of ground clearance.  A friend of mine runs a 12x6 three blade prop on his OS .40 LA.  This combination appears to work well for him but I do not think that the OS .40 LA would be stressed enough to endure this heavy load.
      Several years ago, I got bitten by the Diesel Bug and converted a ST and OS engine to join my other Diesel engines.  I am planning to run the OS DDD .40 Diesel in an ARF Nobler.  I have also used the OS Diesel along with ST G20/.15D and a MVVS D7 .15.  Both of those engines run very well powering stunters with 40" wing spans.  Oh that Diesel aroma!!!!!!!!!!!!!!!!
        Be well my friends,
        Frank McCune
« Reply #6 on: May 31, 2016, 12:19:03 PM »
      Hello Brett et.al.:
Stressed enough???  As in parts breaking off or something?
That's not how IC engines work.  Put too big of a prop on it and it'll run slower than it's "happy speed", and, if the venturi is big, probably get hot from a combination of overwork and inadequate cooling.  But you can to some extent change an engine's "happy speed" by venturi size changes and what fuel you use -- I suspect that I could get a 40LA to run cool and happy all day on a 12x6 three-blade; it'd just be putting out as much power as a typical modern 15, at a really low RPM and with poor speed regulation.
Offline Phil Krankowski
« Reply #7 on: May 31, 2016, 02:55:17 PM »
If you want the same rpm and engine load this is reasonable, but increasing pitch will increase theoretical max speed, which may be a problem.  Keeping pitch and decreasing only diameter may cause rpm to increase, due to less load, which will also increase theoretical max speed...
Catch 22
Phil
« Reply #8 on: May 31, 2016, 03:21:25 PM »
Catch 22
Phil
also affected by the camber of the blades , under camber, and "philips entry"
the only way to really know is to bolt it on and see what happens
« Reply #9 on: May 31, 2016, 05:05:37 PM »
Then adjust & repeat.  Any numbers game will only give you a starting point, and cut down on the number of props you have to buy & try.
« Reply #10 on: May 31, 2016, 05:10:39 PM »
Without Frank replying I am going to assume that "stressed" really should be "strong" (enough).
Running a diesel for stunt is often counter intuitive - think more like a fourstroke, they will pull a high gear at lower rpm and then have self imposed limits that prevent overspeeding.
MAAA AUS 73427
« Reply #11 on: May 31, 2016, 05:13:23 PM »
Or adjust the compression to suit the load, that's part of the beauty of running a diesel.
MAAA AUS 73427
« Reply #12 on: May 31, 2016, 06:04:40 PM »
     Hello Chris, Tim and others:
     When I said stressed I meant that the parts of the OS Glow engine may not be strong enough for Diesel Operation.  In the early 70's I was running ST .15 Diesels and was having a great time with 7x6, 8x4 and 9x6 props.  The Brits liked 8x6 props for combat .15 Diesel engines but I never tried one as I thought that the
     ST Diesel engines were not strong enough for turning large props. The moving parts were about the same as the Glow engines.  There may have been some heavier rods and cranks for the Diesel but I would have to look through my parts to confirm this.  The crank shafts for the G20/.15 Glow and the G20/.15D were different as the Diesel required a much smaller shaft port.  I was advised to go to 9x6 and 10x6 props on the Diesels.  I did not do this but I have broken crankshafts, con rods, crank pins , pistons and have blown the jugs, cylinders, off the crankcases on Russian Diesels. I even had a great running Fox .35 Stunt puke a crankshaft in Foxberg on a 9x6 prop.  Overstressed????.  It was running on 10% nitro.
       I think that an engine designed to be run as a Diesel has more robust parts in it compared to a glow engine.  Yes, I realize that one can adjust the compression on a Diesel to match the load.  This is not a mystery as all has to do is listen to the sound of the engine.
      Enough for now! I do not want to get into fuel burn characteristics mixtures etc. glow vs. Diesel. Stoichiometric ?
        The best to all,
        Frank McCune
