  • June 21, 2025, 12:07:20 AM
Author Topic: How do I modify a pipe?  (Read 1478 times)
steven yampolsky
« on: April 17, 2013, 10:30:15 PM »
I have a pipe with an exhaust stinger pointing straight back. I would like to move sot that the stinger exits at an angle. I also want to make a stinger 1.5" long too.
Can someone help me answer a few questions:
1) What kind of resin can I use to patch up the hole after I cut off the stinger? I
2) What can I use to make the new stinger? Can I use a regular CF tube? What ID does it need to be?
I would also appreciate any pointers on how to get this done properly.
The pipe is one of those long and skinny ones used for 40VF's.
Re: How do I modify a pipe?
« Reply #1 on: April 17, 2013, 10:40:11 PM »
   You can probably use a graphite arrowshaft with at least 5/16 ID, and JB Weld. I wouldn't make it 1.5" long!  But what is wrong with a conventional stinger?
Offline Joseph Lijoi
« Reply #2 on: April 18, 2013, 08:20:59 AM »
They make clamp on silicone exhaust diverters for this application.
steven yampolsky
« Reply #3 on: April 18, 2013, 07:57:32 PM »
The tunnel back wall former is 1" from the tip of the pipe. Rubber deflector binds restricting the flow.
« Reply #4 on: April 18, 2013, 08:08:56 PM »
I recall seeing Howard with a "Utah Pipe" with dual exhaust on his RO-Jett. One was aluminum tubing, could have been from the LHS or some high-tech chit, but it looked like it was installed with (slow) JB Weld. Be sure to let it cure the required time, lest it spew sparks  f~ of molten epoxy with the rest of the exhaust residue. You might email Howard or maybe whoever bought Howard's IC stuff could chime in.  H^^ Steve
Online Howard Rush
« Reply #5 on: April 18, 2013, 09:10:09 PM »
I think I used a piece of flap torque tube for the second exhaust.  It was made from 350-degree prepreg, so heat was no problem.  JB Weld should work just fine that far back, particularly with a VF.  Email me your postal address, Steve, and I'll send you some bits.
Steven Yampolsky
« Reply #6 on: April 19, 2013, 03:17:12 PM »
How's this for an attempt? The stinger is flush with the pipe surface. Do you think it will work? ID is 3/8
« Reply #7 on: April 19, 2013, 03:38:54 PM »
You already did it so it will work.  Looks pretty cool.
« Reply #8 on: April 19, 2013, 09:28:09 PM »
That will work, but maybe not for long, The brass will come loose normally, The best thing to do this with is a carbon tube or Cf golfshaft, arrowshaft, scuffed up very well, next would be a thinwall al. tube, scuffed very well.
You may get 25 flights or several 100, but as I have seen over the years brass is not a good material for this application.
Good luck with it
Steven Yampolsky
« Reply #9 on: May 02, 2013, 09:44:05 PM »
Howard Rush sent me proper bits to use. Thank you Howard!
« Reply #10 on: May 03, 2013, 12:36:50 PM »
I've had some poor luck adding an extension to my RO-Jett aluminum muffler.  The exhaust aluminum exit tubing is very short, and those rubber doo-dads held on by ty-wraps don't hold well.
What finally worked was some brass tubing with a 2-56 bolt through the joint and some JB Weld.  Note:  vibration + heat will weaken a JB Weld joint.  So the bolt is necessary.
