Hi Dwayne,
Thanks for the explanation. I think I've got it all figured out. The pressure is always capped or connected to pressure, one or the other. If there is a third fill tube, I am thinking that it can be capped or not capped. Today, for the first time, I used a clunk tank which I plumbed with three tubes for a Doodle Streak. Several times I flew with both the overflow and the fill tube capped. Several times, I only had the overflow capped. Performance was the same.
However, it really went rich when it got in the air (a Fox 35 with a Randy Smith nva). Finally, on the third and fourth flights, with needle turned in quite a bit with a fast 2 cycle at takeoff, it ran fairly good. It would slow in the air but did the 4-2-4 nicely for maneuvers. This tank a cheap Chinese clunk tank which came from the Tutor II. Only problem, can't see the tubes inside so I'm guessing about the overflow. I think I'm getting this figured out.
Notice that the capped off tube is overflow, the one not capped is fill, and of course the clunk is attached to the motor.
