  • July 16, 2025, 07:54:53 PM
Author Topic: Help me identify a Fox ..35 Stunt  (Read 784 times)
Offline frank mccune
« on: July 05, 2013, 05:51:28 PM »
     Hi:
     I recently acquired a Fox Stunt that I need some help identifying.  It was given to this guy in 1968 as an anniversary model.  Perhaps the 20 anniversary model.
      It looks like the typical Fox stunt with a few exceptions.  One is the case has a somewhat textured outside finish.  The other thing is that the crank disk is much  thick and has a deep concave bevel pointing into the hole in the shaft. The hole in the shaft looks much larger than the standard Stunt.  The bore in the venturi also looks a bit larger.
     This was a great running engine 30 years ago!
     Any idea as to what it is?
        Tia,
        Frank
Offline 55chevr
Re: Help me identify a Fox ..35 Stunt
« Reply #1 on: July 05, 2013, 06:48:57 PM »
Just a suggestion but a photo would be a real help in ID-ing your engine.
Joe
Joe Daly
« Reply #2 on: July 07, 2013, 07:15:21 AM »
     Hi:
     I did some research and I think that this engine is a 1963 Anniversary engine.
        Frank
