Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 21, 2025, 07:42:48 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
HELP I can not get head on Fox .25 ??????????????
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: HELP I can not get head on Fox .25 ?????????????? (Read 1516 times)
frank mccune
AMA Member
Trade Count:
0
Admiral
on:
August 26, 2013, 07:42:08 AM »
Hi Gang:
I recently pulled the head on an older Fox .25, 50's, to check for binding after a crash. Now I can not get the head screws to enter the holes in the case with the cylinder in place. The holes for the head screws are slightly covered by the cylinder flange thus preventing the screws from starting into the holes.
Possible suggestions for a solution are:
Grind notches in the cylinder flange to provide clearance for the screws with the trusty Dremel Tool or ?
Any other suggestions?
Tia,
Frank
Logged
Phil Krankowski
Trade Count:
0
Admiral
Re: HELP I can not get head on Fox .25 ??????????????
Reply #1 on:
August 26, 2013, 07:46:14 AM »
Did you mark the liner and case during tear down? Is the liner oriented properly in the case? (180 off?)
Logged
frank mccune
AMA Member
Trade Count:
0
Admiral
Reply #2 on:
August 26, 2013, 01:11:03 PM »
Hi Phil et. al.:
No, I did not mark the crankcase and sleeve when I removed the sleeve from the engine. The reason is, it will only properly line up one way with the ports correctly oriented.
There are no notches in the flange of the liner to clear the head screws. One can see that the flange covers a portion of the head screw holes and the inital assembly scratched the lip of the liner with the threads of the screws.
I guess that it is time to cut light notches in the liner to facilitate assembly.
Any more suggestions?
Tia,
Frank
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #3 on:
August 26, 2013, 01:20:42 PM »
Hi Frank,
That is very unusual, all the old '50s Fox .25 that I have already do have "notches" cut in the cylinder flange to clear the bolts. If that head was on the engine, the notches have to be there, right?
BIG Bear
RNMM/AMM
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #4 on:
August 26, 2013, 04:34:50 PM »
Frank,
Sounds like you found the cause of the binding after the crash. If you have the liner out can the head go onto the bolt hole? This could be just some off set holes from the factory. Or the hit caused the cylinder to egg shape and once the bolts are out it moved out a couple thousands. If the piston moves freely without the head on you could drill out the head bolt holes to get them lined up. I do this on Fox 35's all the time. Some of the heads have holes in the case that are just a little tight and will cause the engine to bind as the head is tightened. For my stuff I run a # 30 drill through all the head holes (I have also opened some of the backplate holes to a #29 drill). This usually does it.
Best, DennisT
Logged
frank mccune
AMA Member
Trade Count:
0
Admiral
Reply #5 on:
August 26, 2013, 04:41:51 PM »
Hi Bill Little et. al.:
Confession time! My engine did indeed have the notches in the cylinder liner! I just failed to see them until I cleaned the sleeve, put on glasses and turned on a spot light! Lol The screws fit great now!
I still have the tight fit on the p&c but that is going to stay that way until I run the engine again! It may be a good thing!
Thanks for the help,
Frank
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #6 on:
August 26, 2013, 04:51:25 PM »
Hi Frank,
Glad that the head bolt mystery is cleared up!
I love the old .25 as a stunt engine, but I did pick one up which was bolted to a VooDoo.
I thought it might have been used for slow combat........ the engine seems to be almost as strong as a Fox .35, and seems to run just a touch better, also.
I tried one of the "new" Fox .25 which had the "bolt on" carb/venturi and it definitely does NOT run like the old .25. Couldn't even get it to run in a dependable wet 2.
BIG Bear
RNMM/AMM
Logged
Big Bear
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
