  • June 19, 2025, 07:14:06 PM
Author Topic: Heat Ranges for Glow Plugs ( again)  (Read 1362 times)
Offline John Leidle
« on: March 25, 2020, 08:55:56 AM »
  I asked for this information in SSW but didn't write down the responses & now SSW is gone. So like Johnny Thunder sang .. " One more Time Now "  Can you guys tell me what makes a plug hotter? 2 kinds of plug bodies those with the cavity that the filament is in the first one  has a small bore & the second has a big bore . Which is hotter ?
   Thanks , John L.
Offline Dave Moritz
Re: Heat Ranges for Glow Plugs ( again)
« Reply #1 on: March 26, 2020, 12:03:01 PM »
Mr. M-Man:  Grrreat!  It doesn't get any simpler than that. Thanks.
Dave Mo
Offline John Leidle
« Reply #2 on: March 26, 2020, 01:17:27 PM »
   Thanks Guys ,
  I had it potentially backwards.
Offline Al Ferraro
« Reply #3 on: March 26, 2020, 09:31:21 PM »
 For stunt and sport flying, just use a Sig p2003 plug.
Al
Offline Reptoid
« Reply #4 on: March 27, 2020, 04:08:57 PM »
Al
Some of the modern schnuerle ported engines run better without the idle bar
       Don
       AMA # 3882
« Reply #5 on: March 31, 2020, 02:08:21 AM »
This prior thread here on StuntHanger discussed much of this topic. It also refers to some prior analysis worth reading.
https://stunthanger.com/smf/engine-set-up-tips/hottest-plug/msg538110/#msg538110
Offline John Leidle
« Reply #6 on: March 31, 2020, 09:26:11 AM »
    Thanks Dave.
  John L.
