  • July 07, 2025, 11:53:20 PM
Author Topic: Saito 40  (Read 741 times)
Offline Paul Allen
Saito 40
« on: May 10, 2008, 07:31:48 PM »
Guy's
       Can some one tell me the mounting hole dimensions for the Saito 40.
Offline Gordon Tarbell
Re: Saito 40
« Reply #1 on: May 10, 2008, 08:42:24 PM »
This is from the Saito booklet in the box Saito 40a    From the prop hub face to the center  of the front mounting holes    dimension H-   46mm (1.8110").     mounting hole front to back on center  dimension B-   15mm (.5905").  Mounting hole patern width on center   dimension A-  38mm (1.4965") Crankcase width (width between engine mount bearers    dimension G-31mm(1.2205") I might be off on the conversions just an RCH, I hope that helps.
Gordon Tarbell AMA 15019
Offline Paul Allen
Re: Saito 40
« Reply #2 on: May 11, 2008, 03:11:17 AM »
Thanks Gordon
