  • June 17, 2025, 06:51:43 PM
Author Topic: Super Tiger G34 ?  (Read 1252 times)
Offline Rob Killick
Super Tiger G34 ?
« on: October 18, 2006, 08:28:35 PM »
Gentlemen ,
I purchased a ST G34 about 10 years ago (R/C version) and recently picked up 2 N/V assemblies and 2 venturies from Tower Hobbies .
My question is this:
Are there any other venturie/NV assemblies that will work better with this motor ?
Here are the venturie specs. from Tower Hobbies
NOTES FROM OUR TECH DEPARTMENT
   This is the Venturi for the Supertigre G34 Control Line engine, SUPG0805.
FEATURES: Aluminum construction
INCLUDES: One venturi and O-ring
SPECS:    Neck outside diameter:     .47"    (12mm)
          Neck inside diameter:      .28"    (7mm)
          Throat outside diameter:   .58"    (15mm)
          Throat inside diameter:    .51"    (13mm)
COMMENTS: If you need the needle valve assembly order SUPG4919.
Thanks in advance  f~
Rob Killick , MAAC 33300
Offline Bob Zambelli
Re: Super Tiger G34 ?
« Reply #1 on: October 19, 2006, 09:06:06 AM »
How does it work now?
Offline Rob Killick
« Reply #2 on: October 19, 2006, 04:34:29 PM »
Hi Bob ,
I've never run the motor , as of yet .
The snow is starting to fly around here ...
I guess the test run(s) will have to start next spring (I don't think it will go over too well running it in the basement  **)) .
