  • July 15, 2025, 10:57:56 PM
Author Topic: Has anyone used this Tiger 35?  (Read 1631 times)
Offline Robert Zambelli
« on: February 08, 2015, 05:18:38 PM »
Came across this recently - twin ring, ball bearing, baffle piston, weighs 9 ounces.
G 21 in a large "V" on the bypass.
It's virtually new - just a bit dirty.
Anyone know its purpose?
Online Bill Morell
Re: Has anyone used this Tiger 35?
« Reply #1 on: February 08, 2015, 08:02:23 PM »
I believe that is a 1st model G/21 35. You can tell by the bolt on front end and the straight up venturi. I used to haveone and it  was a
good runner. I had new rings put on it and it sold for big bucks on eBay. I was stunned to say the least as I had only paid $10 for it.
« Last Edit: February 09, 2015, 09:17:15 AM by Bill Morell »
Bill Morell
Vietnam 72-73
« Reply #2 on: February 09, 2015, 05:48:11 AM »
Hi, Bill - thanks for that information.
I dug it out of a box of old Tigers and didn't know a thing about it.
Might be a bit heavy for a stunt engine - in fact, I'm pretty sure I have a speed 29 that's in the same case.
I thought it might have been intended for stunt as there was no speed class for a 35.
Make sense?
Online Bill Morell
« Reply #3 on: February 09, 2015, 09:19:38 AM »
Actually you might be surprised at just how well it runs. Put it in something that might be a little tail heavy. Frank Bowman has rings for this engine if you ever need to change them. I reccomend it as they are much better rings.
Bill Morell
Vietnam 72-73
« Reply #4 on: February 11, 2015, 12:27:22 AM »
Combat or "C" Gas free flight. Saw one run, back in the early '60's. Made a lot of noise, sounded powerful, but it had fuel tank problems or maybe just fuel problems.  D>K Steve
« Reply #5 on: February 11, 2015, 05:47:49 AM »
Bill and Steve - thanks for the replies.
I have the prototype Brodak P-40 ARC that I have used as a test plane in the past.
I will mount the Tiger 35 on that and see how it performs.
« Reply #6 on: February 12, 2015, 10:34:38 PM »
Theyre Wot they used for STUNT in Italy at the time .
Dunno if a muffler will help . Cant see it . Nitro does , if its gutless - which is unlikely .
Early ST's had very hard liners . Carefull you dont seize it . Vibration ? might pay to
' Anti Foam ' ( armourall etc ) the Fuel . If its shaking it could go lean .
Have an Identical mint one , I may put in a Mk 1 T- Bird .Havnt run it .
