  • June 22, 2025, 01:15:04 PM
Author Topic: Nitro and humidity  (Read 2069 times)
Offline Ty Marcucci
Nitro and humidity
« on: August 18, 2008, 03:19:57 PM »
 D>K
« Last Edit: June 19, 2017, 02:49:55 PM by Ty Marcucci »
Ty Marcucci
Offline Jim Oliver
Re: Nitro and humidity
« Reply #1 on: August 18, 2008, 08:44:27 PM »
Hey Ty,
Please post a pic of it if you can.  You and I fought the same battle at Paducah and we both lost..............
Jim
Jim Oliver
AMA 18475
Offline Jim Oliver
« Reply #2 on: August 19, 2008, 08:27:32 PM »
Thanks Ty.........
Not sure it will solve my problem, but I need all the help I can get.
Jim
Jim Oliver
AMA 18475
« Reply #3 on: August 27, 2008, 12:13:11 PM »
Gonna get me one, and let Randy tell us what to do based on the conditions until I learn! LOL!!!!
Does turning the needle really have to be done?  How about just more or less fuel?  (showing my ignorance here, but I rely on others in this area!)  I don't do a lot of needle movement during the course of a season.................
Mongo
« Reply #4 on: August 27, 2008, 01:25:55 PM »
Bill,
In my experience, You do need to adjust the needle. I fly at home, 3000' altitude, typically 80 degree weather during summer, and very low humidity. I fly contests typically at about 200 ' ASL, 60 to 70 degree weather, and 50% humidity. As I have learned to understand my power system, and refiine it. I do find myself making changes to the fuel load I put in, and to the needle setting. There is more or less slugs of oxegyn in the air the engine is breathing, so it needs different levels of fuel to burn and perform the same. This is probably the simplest breakdown of what I see possible. Others can give the technical numbers if they want, I was just trying to keep it simple,,
« Reply #5 on: September 02, 2008, 05:59:50 PM »
How can humidity matter much?  Does water condense and then evaporate in an engine?  Has anybody done any calculating?  I have seen name-brand stunt flyers pay close attention to air density.  For how airplanes fly, I think Reynolds number / (foot * speed) is useful.  Maybe that's why people often ask me what's nu.
Offline don Burke
« Reply #6 on: September 02, 2008, 06:55:53 PM »
I think it has to do with the water added to the air, the total volume of oxygen available to the engine per stroke goes down since it is fed through a restrictor, the venturi.  The same volume of air fuel mix goes into the engine, but there's water in there that doesn't burn, and with less o2, less power.
We racers see a drop in performance in Muncie compared to the West Coast.  In a lot of the classes where we either have venturi diam specs or "standard fuel", we have to richen the needle and lower the prop pitch to keep our engines from overheating.  Result, slower speeds and fewer laps/tank.  Those used to flying in the high humidity probably don't see any difference.
don Burke AMA 843
Menifee, CA
« Reply #7 on: September 02, 2008, 07:57:54 PM »
Calculate how much of that effect is water and how much is density.
The prop is another matter.  It doesn't give a hoot about oxygen; it just cares about density.  I'll bet it is susceptible to Reynolds number changes, though.
« Reply #8 on: September 02, 2008, 11:44:21 PM »
Still can't get you to calculate anything, eh? The more computers and fancy software we get, the less we cipher.
I wondered about this awhile back and took four extreme conditions:
59 degrees F, 12% relative humidity
59 degrees F, 95% relative humidity
100 degrees F, 12% relative humidity
100 degrees F, 95% relative humidity
lb. of water/lb. of air for these cases:
.0105
.0015
.005
.04
Looking at my notes, it appears that I figured the mole fraction of water for each case and figured the density change and oxygen fraction change for constant temperature and pressure.  As a rough approximation and without going to any real effort, it looks like the oxygen change from Phoenix (12% relative humidity) to Houston (95% relative humidity) at 100 degrees about the same as a 1,700-ft. altitude change at standard atmospheric conditions.  The change from Eastern Washington (59 degrees F, 12% relative humidity) to Western Washington (59 degrees F, 95% relative humidity) would be about the same as a 500-ft. altitude change.
I think the change you saw in Paducah was due to temperature.  I betcha that the fraction of water in the air was constant, although I'm too lazy to look it up, let alone learn how to pronounce "psychrometric".  The density fraction of the low and high temperatures there = (459 + 76)/(459 + 87) = .98, which is about the same as 800 ft. altitude change at standard conditions, i.e. interpolating the standard atmosphere in my Pratt & Whitney Handbook, which is as much effort as I'm willing to put out.
I hope that one of you guys who worry about stuff like this will do the calculating and make a chart so I'll know what to do going between Seattle and Muncie.  I still haven't got my stuff working right since getting home.  I'm going to give the props another twist and try that tomorrow.
Offline Dennis Vander Kuur
« Reply #9 on: September 19, 2008, 12:09:09 PM »
Ty,
Maybe your experience isn't unique and you're giving up too soon. For the last two seasons my engine run duration experience with my LEGACY has been pretty consistant. I run a piped PA .65 with a 6 ounce tank using SIG Champion 10% nitro, 20% oil (50/50 syn/castor). I always fill the tank to overflow, use the same prop, the same fuel, and run 10,200 rpm. For the last two years, at numerous contests (including Paducah), with the normal variations in temperature and humidity, my run times have always been between 6:45 to 7:15. So it was a no-brainer for me to not under or over run no matter the temperature or humidity. HOWEVER, I flew at Mt. Joy last weekend IN THE RAIN. Because of the fairly constant rainfall no one had a chance to put up a needle practice flight. You "run what you brung" for your official flight. During my first official flight I found I had to lean out the needle by over one turn to get back to my normal 10,200 rpm. And on the flight I almost over ran with a time of 7:49. And I wasn't the only one. Many contestants over ran or came very close to over running. Everyone was commenting on how long their engines were running (except the electric guys  n~). The humble, uneducated, collective guess was that the raining 100% humidity air had less oxygen in each air intake charge. Therefore, we had to needle leaner to restore the proper fuel/air ratio and this increased the run time (if you used your normal amount of fuel). Please don't kill the mesenger.
DennisV
Dennis L. Vander Kuur
AMA 29292
Offline Pinecone
« Reply #10 on: October 16, 2008, 05:42:16 PM »
Clouds are up high not because they are lighter.  They are up there because that is the condensation level, the point where the temperature drops to the dew point of the air.
But water vapor is less dense than air.  The bad news for full scale is hot, humid, and high.  Leads to needing a LOT more runway.
Terry Carraway
AMA 47402
