Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 17, 2025, 03:50:48 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Glow plug > RPM drop
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Glow plug > RPM drop (Read 1760 times)
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
on:
February 13, 2009, 08:42:19 PM »
I've often read that if the rpm drops when you disconnect battery the glow plug is either bad or to cold heat range. I've tried Fox RC long, Fox Miracle, Thunderbolt RC long, and Sig RC long and they all have rpm drop when battery is disconnected. All new plugs in a variety of engines. So what's up with that ?
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
ray copeland
25 supporter
Trade Count:
0
Captain
Re: Glow plug > RPM drop
Reply #1 on:
February 13, 2009, 08:53:27 PM »
Usually only happens to me when i have the needle too rich to begin with. Maybe try setting the needle a little more lean then removing the battery clip.. In my very few years of flying i have found that if a plug is bad , but good enough to start ,, it will loose rpm's even on a good needle setting.. or be sluggish when on a load. Hope you get this one figured out!!!
Logged
Ray from Greensboro, North Carolina , six laps inverted so far with my hand held vertically!!! (forgot to mention, none level!) AMA# 902150
michael battley
Trade Count:
0
New Pilot
Reply #2 on:
February 14, 2009, 06:12:40 PM »
Could be a number of things, as already stated, it's most likely a little too rich, but could be: engine showing signs of wear, water in the fuel, you might be taking the igniter away too early before the engine has a chance to warm up.
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #3 on:
February 15, 2009, 03:49:27 PM »
I don't consider my engine 'warmed up' until I've pinched off the muffler pressure line or blocked off the uniflow vent, to lean the engine to peak or a little sag lean. Then I tach then engine and adjust the NV if needed.
When the battery comes off depends on whether the engine is a sidewinder, or upright or inverted for starting, but before taching and needling. If I've turned the plane (inverted engine) over to start, the battery comes off before it's turned back over. Hope this helps somebody.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Brian Hampton
Trade Count:
0
Captain
Reply #4 on:
February 16, 2009, 12:28:12 AM »
Generally it's a sign the plug is a bit too cool for the particular combination of engine/fuel/prop load and phase of the moon
. Plug heat range is one of the things that sets the ignition timing and the closer the timing is to ideal the more power and therefore the revs you get. With the engine running and power connected to the plug it's got both catalytic heat and electrical power to heat it, in effect overdriving the heat range. Disconnect the power, the plug cools down a little, the timing changes to less than optimum and the engine loses revs.
If you find a rev drop with the hottest plug available then adding nitro or raising the compression will advance the ignition timing. Personally though I don't worry if there's a minor rev drop although lately I've started using the Taipan 4 stroke plug which gives no discernible change when using zero nitro fuel in an Enya 60-IIIB and several others.
Logged
Leo Mehl
Trade Count:
0
Admiral
Reply #5 on:
March 29, 2009, 07:08:47 PM »
If rpm drops after you take battery off on the thunderbolt plug it means its time to replace it before it burns out!
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
