  • July 11, 2025, 05:22:25 PM
Author Topic: What to do with a Seized Cox engine  (Read 1016 times)
Offline Angelo Rosa
« on: June 21, 2008, 06:24:08 PM »
Hi, Everyone!
A friend of mine just gave me a seized Cox engine. It was in a plastic bag lined with gunked-up fuel residue.  What can I do to un-seized this engine that seems almost new on the outside?
Thanks for the help!
All the best.
Angelo
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: What to do with a Seized Cox engine
« Reply #1 on: June 21, 2008, 07:57:48 PM »
Soak it in fuel for a day then take it apart and clean well with same fuel. Thats the easiest #^
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Ralph Wenzel (d)
« Reply #2 on: June 22, 2008, 04:07:46 AM »
If the engine is truly just "gunked up" with old Castor Oil, then preheat your oven to 350° F., install a wood prop,  and place the engine a pie pan. After about 10 minutes, remove the engine from the oven. USE OVEN MITTS!!! Hold the engine in one hand and gently rock the prop until you can rotate it. Then clean the engine with solvent.
Ralph Wenzel
AMA 495785 League City, TX
Offline Tom Perry
« Reply #3 on: June 22, 2008, 08:12:56 AM »
after all of the above your NVA and fuel passages may still be blocked.  I've found it useful to use a small syringe to push some fuel through the passages to clean them out.  :)
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #4 on: June 22, 2008, 12:02:57 PM »
Take a heatgun for monokote and slowly heat it up till the castor melts.  It usually doesnt take much.
