  • June 16, 2025, 07:46:43 PM
Author Topic: Glo Engine timing  (Read 1047 times)
Offline Phil Coopy
Glo Engine timing
« on: September 12, 2008, 07:15:41 PM »
I asked this on the open forum with no results so I thought it might get a response here.
Glo engine timing is most likely a black art but, is there a primer out there somewhere where I can learn something about it?
Phil
Offline Ralph Wenzel (d)
Re: Glo Engine timing
« Reply #1 on: September 12, 2008, 07:52:48 PM »
There was a book published 50-60 years ago titled, "Model Engine Design and Construction" which had a couple of chapters devoted to timing. I sent it to Henry Nelson so he could get his engines to run right . . .<Giggle>
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Willis Swindell
« Reply #2 on: September 12, 2008, 08:02:52 PM »
There is always the Two-Stroke Tuner’s Handbook by Gorden Jennings.
Willis
Alan Hahn
« Reply #3 on: September 13, 2008, 09:52:56 AM »
Phil,
The book by Dave Gierke on "2-Stroke Glow Engines" has some good stuff in it. Not sure if it is exactly what you want, but I learned a lot from it.
Dave Adamisin
« Reply #4 on: September 19, 2008, 07:14:11 PM »
Willis
Ditto. This book removes the magic and makes it pretty clear.
Offline Phil Coopy
« Reply #5 on: October 04, 2008, 06:08:57 PM »
Thanks guys......bought a copy of the Two-Stroke TUners Handbook....boy, they don't give that one away.
Phil
