Hi,
I'm about to install two Brodak wide wedge, uniflow, tubes forward tanks, one in a kitted Smoothie and the other in a Top Flight Nobler. I have a question. Is there any preference as to where to have the fill tube and the overflow tube exit the fuselage. Some setups I've considered are:
Fill tube out the top - and overflow tube out the bottom. Or:
The fill tube out the top and overflow tube out the side. Or:
The fill tube out the side and the overflow tube out the bottom.
I understand that the overflow tube must be capped during flight.
What kind of setups have you found that really work well.
By the way, I'm jettisoning two magnum style tanks. One already broke on the inside of the tank. The other one is still intact.
Thanks in advance for your suggestions.
