  • June 14, 2025, 11:41:12 PM
Author Topic: Fuel Mixing  (Read 1176 times)
Offline DanielGelinas
Fuel Mixing
« on: January 31, 2012, 12:06:53 PM »
Can anyone help me with fuel mixing?
I have one gallon of 10% nitro, 29% castor.
I would like to mix in some synthetic oil. How much synthetic oil and alcohol do I need to ADD to my gallon to end up with 11% synthetic, 15% castor?
I'm assuming it will lower my nitro content...
Whats the math involved? HB~>
Many thanks!!
-Daniel H^^ H^^
Offline Bill Adair
  • AMA 182626
Re: Fuel Mixing
« Reply #1 on: January 31, 2012, 01:21:56 PM »
Dan,
Try this site, and change the numbers in their work sheet till you get it to the desired level. I even use their formula for mixing diesel fuel, by substituting ingredients. Scroll way down till you see the options to Add oil only, or Add Nitro and oil.
http://www.nitrorc.com/default2.asp?Introduction=http://www.nitrorc.com/fuelws
Re: Fuel Mixing
« Reply #2 on: January 31, 2012, 02:22:49 PM »
Hi Bill,
I looked into this site already. It only works if you add oil. I do want to add oil (syn) but don't want to end up with more oil content than 25-26% total. Problem is that I'm starting with 29% castor.
I need to add a considerable amount of alcohol to <CUT> the 29% castor before adding 11% syn.  HB~>
-Dan
Online Tim Wescott
Re: Fuel Mixing
« Reply #3 on: January 31, 2012, 02:30:22 PM »
If you have 29% castor now, in one gallon of fuel, you have 0.29 gallons of castor.
If you have 0.29 gallons of castor and you want 15% castor, you want to increase your total volume to
(0.29 gal)/0.15 = 1.933 gallons.
So whatever else you do, you need to add 0.933 gallons total of stuff.
Of that 1.933 gallons that you end up with, you want 11% to be synthetic.  That works out to needing to add
(1.933 gal)(0.11) = 0.213 gallons.
So, of the 0.933 gallons that you're adding, 0.213 are synthetic oil, and you need to make up the rest in methanol.  That works out to
0.933gal - 0.213gal = 0.720gal
So 92 ounces (11 1/2 cups) of methanol,
27 ounces (3 1/4 cups + 2 tablespoons) of synthetic,
and your fuel.
Offline Steve Hines
Re: Fuel Mixing
« Reply #4 on: January 31, 2012, 09:16:22 PM »
You could mix what you have with Bryon fuels, they say is 18% syn and that would give you 9 and 14.5. thats 23.5. I did this with Sig syn plus and caster gave me 10 and 10 It worked good.
Re: Fuel Mixing
« Reply #5 on: February 01, 2012, 08:50:56 PM »
Thanks guys! Thats exactly the info I needed. y1 y1
-Daniel H^^
Re: Fuel Mixing
« Reply #6 on: February 02, 2012, 02:52:43 AM »
Without getting too deep into the math, you will end up with about 40% total oil.  That's some pretty oily fuel without much energy.
Instead of just adding the synthetic oil, maybe you should mix the 29% fuel with some all-synthetic FUEL, not just the lubricant.
Online Tim Wescott
Re: Fuel Mixing
« Reply #7 on: February 02, 2012, 08:41:24 AM »
Since when has 11% + 15% added up to 40%?  When I was growing up it was always 11 + 15 = 26.
Granted, 26% is a tad high -- but it's not 40%.
