  • June 21, 2025, 12:19:35 AM
Author Topic: Fuel Line Filters  (Read 1881 times)
Online James Mills
Fuel Line Filters
« on: October 01, 2006, 10:44:59 PM »
What is the best fuel line filter to use?
James
AMA 491167
Offline RC Storick
Re: Fuel Line Filters
« Reply #1 on: October 02, 2006, 07:36:16 AM »
I use Crap-Traps
Offline Charlie Pate
« Reply #2 on: November 02, 2006, 04:04:52 PM »
The crap traps are directional-- pay strict attention!
A very good filter Highly reccommended. n1
Offline Ralph Wenzel (d)
« Reply #3 on: November 02, 2006, 06:41:37 PM »
I like the 2-part aluminum filters that Richard Oliver sells. $5 each, 5 for $20. If it gets dirty, just cleanthe filter screen, screw it back together, and go.
Ralph Wenzel
AMA 495785 League City, TX
Offline peabody
« Reply #4 on: November 02, 2006, 06:49:44 PM »
I am a fan of RO's filters as well....
I use a pretty good ceramic auto filter as I fill the tank.....
Offline Ward Van Duzer
« Reply #5 on: November 10, 2006, 10:58:56 AM »
A lot of folks like the crap trap, but I've been driven nuts twice by "leakers". You don't want your filters to leak air into the fuel line.
ASK ME HOW I KNOW?
I use the aluminum screw apart ones that I can clean.  Mine come from H&R Engineering.
Offline Ron Merrill
« Reply #6 on: November 10, 2006, 11:22:16 AM »
Love RO's filters. Ron.  AP^
Offline Jim Thomerson
« Reply #7 on: November 10, 2006, 11:52:22 AM »
I've had one crap trap which leaked.  Tied it down on each end with wire and fixed that.  It is on my test stand tank.
« Reply #8 on: November 11, 2006, 10:37:28 AM »
I guess the point is...they will leak! Guess when it will happen?
« Reply #9 on: November 14, 2006, 10:15:29 AM »
Didn't relate the info to Melvin of MBS Model Supply, but, I had a plane that was not adjustable.  John and I started looking for leaks in fuel line, tank and needle valve assembly.  Finally checked the fuel filter and sure enough it a very small leak.  Took it apart to check it.  Then tightened it back together with a hefty wrench and pliers.  No more problems.  Another time it was a small cut in the fuel line on a plane that would start and run for a couple of laps and then quit.  My son found that one.  Later,  DOC Holliday
Offline Jim Morris
« Reply #10 on: November 14, 2006, 04:52:04 PM »
Personally,I dont use a filter between the tank and the engine.I filter it at the syringe inlet then switch to another filter at the outlet,or I use a smaller fuel jug that has a built in filter. The only problem I have had was self induced from not flushing the flux out of the tank after soldering. This way I can eliminate any posible filter problem if I have a bad engine run.Just a thought.
Offline Steve Holt
« Reply #11 on: November 15, 2006, 03:17:09 PM »
Jim,
There is still the possibility of debris from the tank such as plating flaking off or dried up castor.  While it is true that not having a filter reduces one element in bad engine runs, if there is enough debris to plug the filter, it will plug the needle valve.  A good filter installation is good insurance.  I really like the little RO Jett filters, but slip a piece of large fuel tubing over the filter to assure no leaks.
« Reply #12 on: November 15, 2006, 03:24:15 PM »
It's also amazing how much bits of grass, bugs, and dirt can get into a tank, even if it is only open for the fueling process.
The Sullivan crap traps are nice because they can collect a relatively huge amount of dirt and still work fine.  They are less prone to leak if they are strapped down around the middle in the plane.
