  • June 17, 2025, 12:02:26 PM
Author Topic: FP20 versions IDing  (Read 2849 times)
Offline Gordon Tarbell
FP20 versions IDing
« on: March 16, 2012, 08:07:18 PM »
Seems after reading on this forum there are different versions of the FP20. can anyone post pics for identifying  the various sub species of these little jewels? I am thinking of trying to procure one for a plane package to fly the Clint Ormenson 25 stunt class. Are any of the Magnum and TT clones close enough to work with the same Brett Buck tune up?
Gordon Tarbell AMA 15019
Re: FP20 versions IDing
« Reply #1 on: March 16, 2012, 10:49:52 PM »
   As far as I know there are only two consequential different versions, the ABC liner and the iron liner. You can tell them apart from 20 feet if you know what to look for. The iron-liner version has a "raised" channel for the bypass, and the ABC is smooth.
First is iron-liner, second is ABC
« Reply #2 on: March 17, 2012, 09:33:20 AM »
Dang, I just bought one NIB that looks like the first photo. Now I will try to find one that looks like the smooth one for the ABC/ABN P&L since that is the one that gives the killer run.
« Reply #3 on: March 17, 2012, 11:28:05 AM »
Hi Gordon,
The first one I had was an iron/steel version.  Not much difference at all in the way it runs compared to the ABN version.
« Reply #4 on: March 17, 2012, 02:26:31 PM »
So it will still give the BBTU style run?
« Reply #5 on: March 17, 2012, 05:17:54 PM »
Mine did.  AFAIK, the timing is identical.  The MAJOR piece of the BBTU is the 2030 muffler.  Without it, you just get a good running .20 sized engine. ;D
BIG Bear
RNMM/AMM
« Reply #6 on: March 17, 2012, 11:00:24 PM »
Gordon, I have several of both versions of the FP20 and they all run pretty much the same. Maybe a slight advantage to the ABN version for a steadier run, but not enough to lose sleep over. Use the one you have, it'll be fine.
Edit: Hope you enter Stunt 25! It's a "just for fun" event.
« Reply #7 on: March 18, 2012, 11:09:10 AM »
 I am looking forward to flying your .25 event , that is what this is for. That and to get another tool to improve my flying
Offline Chris Wilson
« Reply #8 on: March 19, 2012, 10:41:34 PM »
BIG Bear
RNMM/AMM
Ok, I will bite, why is the 2030 muffler any better than any other?
MAAA AUS 73427
« Reply #9 on: March 19, 2012, 11:13:13 PM »
   I don't know for sure. I do know that the tuning of the pipe, er, muffler is just about right on the "e-2030" compared to the "862". The real reason is that all the initial testing was with the E-2030, because that's what I had,  and it turned out just about perfect.
« Reply #10 on: March 20, 2012, 03:46:01 PM »
Got it, thanks Brett.
MAAA AUS 73427
« Reply #11 on: March 20, 2012, 04:35:24 PM »
Like Brett said, it works better than any other muffler for the desired run style.  With the 2030, you get a real "pipe style" run.  All the parts (APC 9-4, etc..) combined just work that way.  Do something different and it just ain't the same.
BIG Bear
RNMM/AMM
