  • July 16, 2025, 11:02:15 PM
Author Topic: FOX Anti-Burp Bypass Plug Drawing and Photos  (Read 2853 times)
Offline Dennis Vander Kuur
« on: February 10, 2009, 07:32:35 PM »
Greetings,
Frequently the issue comes up about profile-mounted FOX 35 Stunt engines "burping" during outside maneuvers. Long ago someone came up with a generally proven fix for this. The remedy is the installation of a wooden plug in the engine's bypass passage. Several people have had questions about making/installing this bypass plug . Hopefully questions about the placement, dimensions, and material of construction will be answered by the attached drawing and photos. Remember the dimensions on the drawing are approximate - you need to carve and trial fit the plug to your engine.
DennisV
Dennis L. Vander Kuur
AMA 29292
Re: FOX Anti-Burp Bypass Plug Drawing and Photos
« Reply #1 on: February 10, 2009, 08:06:41 PM »
Very good description and pix, Dennis. I do it with JB Weld instead of a stick. Shape it with a Dremel tool.
« Reply #2 on: February 12, 2009, 05:40:10 AM »
Thanks Dennis,  I just printed off a copy to put in my copy of Tom Morris' book on his building techniques.  The book also has jigs, tools and how to's.  Having fun,  DOC Holliday
Offline Phil Coopy
« Reply #3 on: February 12, 2009, 07:56:45 AM »
John, Dennis,
Probably nothing new but I discovered with one of my 35's that the position (front to back) in the bypass made a great deal of difference.  Mine worked best if it was positioned towards the front of the engine and not in the middle of the bypass.  Don't know why. ???
Phil
« Reply #4 on: February 12, 2009, 08:10:37 AM »
This makes me think now of the spray bar position.  Especially the one with a single hole.  DOC Holliday
Offline John KruziK
« Reply #5 on: February 12, 2009, 05:21:39 PM »
I've read about doing that but never realy understood, now I do thanks  John
AMA 874027
Offline Chucky
« Reply #6 on: February 12, 2009, 05:24:28 PM »
Most reliable cure I've found for the Fox .35 burp is the OS .25 LA-S.  Come to the Dark Side, Jedi knight, and experience the full power of The Force!
Chuck Winget
Offline Clayton Berry
  • Grey haired kid to be wary of
« Reply #7 on: February 12, 2009, 06:40:56 PM »
Now that, was funny.
Clayton - forever busy committing random acts of coolness
Offline Ward Van Duzer
« Reply #8 on: February 13, 2009, 08:41:13 AM »
But they didn't make O.S. .25's in 1951...
W.
Offline Phil Coopy
« Reply #9 on: February 13, 2009, 09:39:37 AM »
Like replacing a Flathead V8 with 350 Chevvy....no class. n1
Phil
Offline DanielGelinas
« Reply #10 on: January 23, 2012, 10:24:50 AM »
Hi Guys,
Just wondering how you fuelproof the wood in the Burp fix?
-Daniel
« Reply #11 on: January 23, 2012, 12:30:57 PM »
You don't.
It gets oil soaked.
