  • June 23, 2025, 08:06:58 PM
Author Topic: Magnum XLS .36 and Aero Tiger .36  (Read 1321 times)
Offline Kim Mortimore
« on: August 20, 2009, 03:07:32 PM »
Is the Aero Tiger a drop-in replacement for the Magnum:  case width, bolt hole pattern, distance to thrust washer?
Kim Mortimore
Kim Mortimore
Santa Clara, CA
Offline Larry Wong
Re: Magnum XLS .36 and Aero Tiger .36
« Reply #1 on: August 20, 2009, 03:37:54 PM »
Yes Kim I did it , I use to run Magnum 36 XLS and my Aero Tiger / Thunder Tiger are the same size. y1
Larry
Alan Hahn
« Reply #2 on: August 21, 2009, 08:31:47 AM »
I "think" the TT (or AT) projects out a bit further (to the thrust washer) than the Magnum. The person to ask would be Randy Smith for sure.
« Reply #3 on: August 21, 2009, 03:29:12 PM »
Kim Mortimore
Kim
It is very close the Magnum is about 1 3\2 of an inch longer than the AT36
