  • June 20, 2025, 07:26:54 AM
Author Topic: FOX 45 C/L, BB, SCH, Ring - Part Number 14600  (Read 813 times)
Offline David Felinczak
  • Always Remember
« on: May 21, 2010, 04:32:06 AM »
Can this motor be modified for stunt (4-2 break)applications?
I have a new In-Box never run.
Date Stamp in Box is Feb. 1996.
Thank you in advance for all responses.
David F.
David Felinczak
865337
Offline Jim z
Re: FOX 45 C/L, BB, SCH, Ring - Part Number 14600
« Reply #1 on: May 22, 2010, 12:23:23 AM »
This engine can be modified to run well , I had one reworked by Lew Wollard
 a few years back and ran very well, although a bit on the heavy side.
  • Always Remember
« Reply #2 on: May 22, 2010, 07:42:38 AM »
Jim,Z.
Thank you for the follow up.
The weight is actually good for the Profile Pathfinder.
I currently am flying a Brodak Pathfinder with a Randy Smith
G51 ST and it balances out perfectly.
I did not have to add any weight to the nose. The aircraft can be tail
heavy if you are not careful in construction.
David F.
David Felinczak
865337
