  • June 21, 2025, 02:25:01 AM
Author Topic: fox 40 rework  (Read 1788 times)
Offline bob lindsay
fox 40 rework
« on: July 24, 2007, 09:27:01 AM »
   Is there anyone else other than Lew Woolard who can rework a 40 Fox BB for stunt .
  Also I have a ST 35 that was a R/C engine , can this be converted to C/L ??? ???  H^^
              Bob Lindsay     PS Ihave tried to reach Lew to no avail.
Offline L0U CRANE
Re: fox 40 rework
« Reply #1 on: July 24, 2007, 01:28:48 PM »
Bob,
Have you tried phoning Lew? I think I heard he doesn't much like email. BigIron, any ideas? Lew's Silver Fox is a gem, worth reaching him about it.
The 1970's C-Series ST 35's, as I hear, came in two versions - flat-top piston and baffled piston. The baffled-piston engine is considered much more suitable for stunt than the flat top. Look in the exhaust port with the piston down: the baffle - or fence - should be obvious if it is there.
\BEST\LOU
Offline Ken Deboy
    • Silk and Dope
Re: fox 40 rework
« Reply #2 on: July 24, 2007, 10:38:11 PM »
His engines are available through RSM distribution:
http://www.rsmdistribution.com/engines-02.htm
cheers,
There is a fine line between "hobby" and "mental illness"
Offline bob lindsay
Re: fox 40 rework
« Reply #3 on: July 25, 2007, 12:41:17 PM »
      Thanks Guys   Tite Lines Bob Lindsay H^^ H^^ H^^ H^^
Re: fox 40 rework
« Reply #4 on: July 27, 2007, 01:16:55 AM »
Bob,
Hi Lou,
From personal experience (what ever good that is! LOL!!) I can say the flat top ST 35C will run a pretty good "wet 2", but not a 4-2.
Sir Thomas of Luper had a baffle piston ST 35C that would 4-2 as aggod as any stunt engine I have ever seen.  Don't have a clue as to what if anything had been done to it.
I have two very nice running flat top ones now, but I would rather have the baffle since I like a 4-2 run!  I will admit, though, that when I was building my Spacehound, I was very tempted to put in the flat top and run it like Juri did the original.  10-4 prop and let it wind on up!  The Spacehound ended up with a ST 46. ;D
Offline Marvin Denny
Re: fox 40 rework
« Reply #5 on: July 27, 2007, 06:46:46 PM »
  Sent you an E-Mail on Mr Woolard.
  Bigiron
marvin Denny  AMA  499
Offline bob lindsay
Re: fox 40 rework
« Reply #6 on: July 31, 2007, 11:44:28 AM »
    Bigiron I did not get your e mail for what ever reason . Could you try again or send me a PM through the
  Forum
                             Thanks Bob Lindsay
Re: fox 40 rework
« Reply #7 on: July 31, 2007, 07:24:31 PM »
  Bob,  I sent you a private E-Mail on this forum
  Bigiron
