  • June 21, 2025, 02:13:08 PM
Author Topic: Fox .35 Stunt mounting hole pattern  (Read 2671 times)
Offline David Ruff
« on: April 26, 2015, 04:46:45 PM »
are there any other engines with mounting holes that match the Fox 35 Stunt pattern?
Retired Army
Offline frank mccune
Re: Fox .35 Stunt mounting hole pattern
« Reply #1 on: April 26, 2015, 05:58:53 PM »
        Hi Dave:
        Of course the Fox .19 and .25 three bolt backplate will fit. I checked my 1958 Combat Special and the bolt holes would fit.  I had to remove a bit of wood from the motor mount to make room for the four screw backplate to get it to fit.  I have often used the Fox .25 engine in lieu of the .35 Stunt for power.  I think that it runs much better and has a bit more power that the .35. It is also a bit lighter!
        See you at the club meeting next Sunday.
        Frank McCune
Offline Phil Krankowski
« Reply #2 on: April 26, 2015, 07:54:13 PM »
OS 20FP, 25FP, 25LA almost fit perfectly.  It is like round-off error between metric and inch, so oval the holes in the bearer slightly and the bolts go through.
Phil
Offline David Ruff
« Reply #3 on: April 30, 2015, 01:28:25 PM »
The Evo .36 CL fits
Correction...no it does not.
« Last Edit: May 22, 2015, 07:21:40 PM by David Ruff »
Retired Army
Online Dennis Toth
« Reply #4 on: May 22, 2015, 05:18:10 PM »
I believe the Brodak 40 is a drop in replacement.
Best,     DennisT
« Reply #5 on: May 22, 2015, 09:29:29 PM »
Best,     DennisT
The Brodak is a drop in replacement for the  OS 35 S and  30S, are those the same as a FOX 35  ??
Offline Geoff Goodworth
« Reply #6 on: May 22, 2015, 11:27:47 PM »
Randy, the Brodak 40 is not a straight drop-in replacement for a Fox 35. The holes are different and the engine is longer. When I replaced the Fox 35 in my ARF Oriental, the front holes for the B40 were between the holes for the Fox. I had placed the prop where shown on the Pat Johnston drawing so there was space behind the Fox. The B40 is about 1/16" clear of the firewall.
In the same vein, the OS 25 engines are longer by about 5/16", maybe 3/8".
If you are looking for a straight drop-in replacement on an existing model, I understand that there is/was a Double Star 40 that fits but I don't know about availability.
« Reply #7 on: May 24, 2015, 09:39:11 PM »
I never said  it was, if you read what i wrote I said it was a replacement for a OS 35S or 30S, or at least that was what I was told by the person who had it made.
the only engine I know of that is a direct same size replacement  is as you mentioned  a DS 40
Offline Charles Hofacker
« Reply #8 on: June 10, 2015, 01:03:44 PM »
The ST G34 is very close
