Engine basics => Engine set up tips => Topic started by: David Ruff on April 26, 2015, 04:46:45 PM
are there any other engines with mounting holes that match the Fox 35 Stunt pattern?
Hi Dave:
Of course the Fox .19 and .25 three bolt backplate will fit. I checked my 1958 Combat Special and the bolt holes would fit. I had to remove a bit of wood from the motor mount to make room for the four screw backplate to get it to fit. I have often used the Fox .25 engine in lieu of the .35 Stunt for power. I think that it runs much better and has a bit more power that the .35. It is also a bit lighter!
See you at the club meeting next Sunday.
Frank McCune
OS 20FP, 25FP, 25LA almost fit perfectly. It is like round-off error between metric and inch, so oval the holes in the bearer slightly and the bolts go through.
Phil
The Evo .36 CL fits
Correction...no it does not.
I believe the Brodak 40 is a drop in replacement.
Best, DennisT
Best, DennisT
The Brodak is a drop in replacement for the OS 35 S and 30S, are those the same as a FOX 35 ??
Randy, the Brodak 40 is not a straight drop-in replacement for a Fox 35. The holes are different and the engine is longer. When I replaced the Fox 35 in my ARF Oriental, the front holes for the B40 were between the holes for the Fox. I had placed the prop where shown on the Pat Johnston drawing so there was space behind the Fox. The B40 is about 1/16" clear of the firewall.
In the same vein, the OS 25 engines are longer by about 5/16", maybe 3/8".
If you are looking for a straight drop-in replacement on an existing model, I understand that there is/was a Double Star 40 that fits but I don't know about availability.
I never said it was, if you read what i wrote I said it was a replacement for a OS 35S or 30S, or at least that was what I was told by the person who had it made.
the only engine I know of that is a direct same size replacement is as you mentioned a DS 40
The ST G34 is very close
