  • June 17, 2025, 08:07:03 AM
Author Topic: Tower 40 prop  (Read 2129 times)
Offline Bootlegger
Tower 40 prop
« on: November 30, 2014, 11:28:03 AM »
 Guy's I am running a stock Tower 40 engine with .272-.281 venturi on a 48 oz model, what would be a good prop size to start with?
  The fuel will be 5 & 10 % nitro with 20-22% oil in equal amounts.
 Thanks for all suggestions...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Tower 40 prop
« Reply #1 on: November 30, 2014, 11:30:56 AM »
Steve Helmick pushed me into the ThunderTiger 11x4.5 prop for the Tower 40 and 46 LA, and it seems to work very well for that sized plane.
Other props to try are the APC 11x4 and APC 11.5x4.  I don't know what else APC has to offer in similar sizes, 'cuz I like the TT!
Offline Jim Thomerson
Re: Tower 40 prop
« Reply #2 on: November 30, 2014, 12:38:52 PM »
I found the Supercool petal blade 11x5 to be my favorite.
Offline Bootlegger
Re: Tower 40 prop
« Reply #3 on: November 30, 2014, 03:54:16 PM »
  Guy's I thank all of y'all for the suggestions, ESPECIALLY Ty' s and the cardio work out!!
  Brother Jim T where do you get these props, and what are they made of?
 Again thanks
Gil Causey
AMA# 6964
Offline Dennis Moritz
Re: Tower 40 prop
« Reply #4 on: November 30, 2014, 03:59:42 PM »
10.5x4.5apc
Offline John Fitzgerald
  • No longer an AMA Member
Re: Tower 40 prop
« Reply #5 on: November 30, 2014, 08:58:37 PM »
I have a 10-6 Tiapan on mine.  Flies a modified Hanger 9 PT-19 nicely with 5.5 second laps on 62 foot lines.   Not enough clearance for 11-4.   The Tiapan has wider blades than most.
