  • June 22, 2025, 05:27:30 PM
Author Topic: Enya SS50 x ST G51  (Read 1846 times)
Offline Martin Quartim
    • StuntHobby
Enya SS50 x ST G51
« on: December 10, 2007, 10:34:56 PM »
Has any one tested and compared these two engines?
Martin
Offline dennis lipsett
Re: Enya SS50 x ST G51
« Reply #1 on: December 11, 2007, 12:43:51 PM »
Martin, I have an Enya 50ss and when I was breaking it in I also was breaking in a ST51. There was no real attempt made to document anything at the time but the tach at the end of the run in period said the Enya was a little stronger,'Now that would not be the case if perhaps you had a reworked ST51.
Sorry i can't be of more help.
dennis
« Reply #2 on: December 12, 2007, 08:50:11 PM »
Uh...is it too late to add the Webra .50GT into the mix? Anybody tried one for PA?  ??? Steve
    • StuntHobby
« Reply #3 on: December 21, 2007, 09:10:55 PM »
Thanks Dennis for your reply. Now that Randy is selling Enya Engines we will be hearing more about them next year.
I have done some flying with one and it has a pretty solid run from start to end.
I think the Enya SS50 will come to proof it self as a better engine then the ST G51. It is lighter and built with better materials.
Just for testing, we were able to bolt an Enya SS50 on a old plane that had a ST 51 before without any modifications, just the tank height was different. We didn't flew it enough to tell how good the SS50 really is pulling a 60 size plane. But so far so good.  It felt very strong pulling the old heavy plane with a TopFlite 13x6 Prop. Perhaps a 13x5 would work even better on this engine.
I also did a few flights with the Pathfinder using the Enya SS50. I used the original muffler and the CG come just right on. Tried the  Rev UP 12x5 and a Bolly 12.5x5.5, 10% Wildcat fuel, Enya 3 plug. The Flight was just awesome having so much extra power >big grin<. The Engine ran very constant, like a 4S.
Martin
Online Gordon Tarbell
« Reply #4 on: December 22, 2007, 06:24:51 AM »
How much lighter and more compact is the enya 50 compared to the ST51 do they share the same foot print to make them interchangable  with out mods to the airframe?
Gordon Tarbell AMA 15019
Offline Dick Fowler
« Reply #5 on: December 22, 2007, 03:06:14 PM »
                                       A            B           C           D           E           F           G
Enya              50SS       0.14       1.35       0.71       1.67       1.93       2.00       3.23
Super Tigre      G51        0.14       1.38       0.76       1.65       1.95       1.97       3.24
A= Mounting Hole Diameter
B= Engine Width at Mounting lugs (Crankcase width excluding engine lugs)
C= Fore/Aft Distance between Mounting Holes (Center to Center)
D= Width wise Distance Between Mounting Holes (Center to Center)
E= Distance From Center of Front Mounting Hole To Face of Thrust Washer
F= Overall width of engine mounting lugs
G= Overall Length From Backplate to face of Thrust Washer
Very Close.
Dick Fowler AMA 144077
Kent, OH
« Reply #6 on: December 23, 2007, 08:47:55 PM »
 youve gotta let the ST rev. itll fly 72 Oz. fine on an 11 x 6 on no nitro .
 10 x 6 3 blade and 3 in. spinner .  or 11 1/2 x 5 , or 12 x 4 ..
 I put a few lires though it on the bench in winter .
then a few in a 150 % aeromudler profile Peacemaker .
4 stoking on a 12 x 6 . - 1450  metric thingos ( grammes )
The Fox 59 woulnt do less than 90 mph.
( it flies the 72 oz. S6 fine in wind . - doesnt like a tight muffler holding heat in .
 10 2 mm holes in one of those ST sausage back things with the std outlet blocked is good.)
but if your not 'simpatico' , or ride a honda . stick to the copies .
