  • July 13, 2025, 04:34:01 AM
Author Topic: fox 35 backplates  (Read 3897 times)
Offline mike mullis
fox 35 backplates
« on: December 18, 2007, 07:09:16 AM »
can some one tell me the differences in the fox 35 backplates??   stock,stuffer.etc...and the advantages of either?? thanks alot
Mike Mullis        LaVergne,Tennessee
Alan Hahn
Re: fox 35 backplates
« Reply #1 on: December 18, 2007, 07:57:38 AM »
Well the advantage of the stock backplate is that a lot of dirt would get into the engine if it weren't there--not to mention that fuel draw would be compromised!
Slightly more seriously, my understanding of the stuffer backplate was that it was designed by Marvin Denny to really back up next to the connecting rod so that it (the connecting rod) wouldn't slip back and forth so much. Some people say it helps the infamous Fox burp on profile's, but some say it doesn't.
I am sure you will hear from a lot more people on this one!
« Reply #2 on: December 18, 2007, 09:50:54 AM »
The reason Alan gives is the one I always get from Marvin, who developed them for Fox.  Others say that a side benefit is that they reduce crankcase volume slightly improving fuel draw and helping the burp.
But MArvinsays it is just to keep the rod in place.
« Reply #3 on: December 18, 2007, 11:33:18 AM »
HI Mike
The biggest differance is ,The standard stock backplate that comes on a FOX 35 is made of soft cast aluminum.It is also not a flat surface. The rod can move around a bit with this backplate for and aft.
 This can cause wear on the rod pin and piston\sleeve, not a good thing.
The cnc "stuffer" backplate is turned on a machine from harder aluminum plus it is anodize hard to make the surface more resistant to wear, it is also flat on the surface, and the back plate also goes in deeper to stop the rod from moving for and aft so much, this helps the motor last much longer.
I hope you can picture this.
« Last Edit: December 18, 2007, 02:07:29 PM by RandySmith »
Offline Bob Zambelli
« Reply #4 on: December 18, 2007, 12:19:44 PM »
Randy - will this help?
« Reply #5 on: December 18, 2007, 02:04:57 PM »
HI Bob
Yes, thanks...a picture is worth a thousand words..... #^
« Reply #6 on: December 19, 2007, 05:36:34 AM »
Hi, Randy - here's some more.
10 minutes of soild modeling.  ~^ ~^ ~^
Offline tom hampshire
« Reply #7 on: December 19, 2007, 10:40:59 AM »
The trouble is you guys aren't near cheap enough.  Take a worn backplate with the 'wankel' pattern ground in to it from rod end play, machine or file it flat and JB weld a piece of tinplate to it.  Turn or file to shape.  No need to spend all that money. Tom H.
THIS IS AN APOLITICAL POST,  PRECENSORED BY THE COMMITTEE ON APATHY.
« Reply #8 on: December 19, 2007, 12:43:42 PM »
Tom !  name calling will get ya nowhere...  LL~ We greatly resemble  that remark!!!..  S?P %^@ and I have you know that Im as cheap as the next guy
Offline mike mullis
« Reply #9 on: December 21, 2007, 06:29:55 PM »
thanks for all the info yall...Randy,,,what is the ideal end play for the crankshaft??/ i'm gonna make my own outta 7075 T6 alu.  yeah i'm a machinist, done it for 15 years full time..was just wonderin the what the pros and cons of em were...sure glad i found this forum...a whole lot if nice and. and purty smart folks here when it comes to the little tips and tricks ...i thank all of ya a whole hell of alot.....hope all have a wonderful christmas and a happy new year.....MikeMullis
Offline Marvin Denny
« Reply #10 on: December 21, 2007, 08:42:44 PM »
  Mike, I am not Randy,  but I will tell you what I did.  If you are going to make a custom fit for your engine,   Remove the stock backplate.  With a prop installed and tight, push the shaft as far rearward as you can, and measure the distance from the crank pin end to the edge of the case.  I would take measurements at several locations around the perimeter of the case and use the shortest distance for  the clearance.  Allow 0.005 to 0.010 inch clearance for the backplate  face  to the end of the crank pin WITH OUT A GASKET IN PLACE.  then the gasket will assure plenty of clearance when the engine gets up to operating temperature.
  Have I confused you enough?
  Now I will warn you that MANY (including Duke Fox) have tried the metal you  are proposing to use and other metals as well.  most have developed problems.  If you DO go with aluminum (and 7075 is a wonderful alloy)   you should coat the face where the rod rubs with some material other than aluminum as  when aluminum rubs against aluminum severe galling and spalling will occur.  Nylon is difficult to put on and often comes off with disastrous results.  I would  opt for HARD ANODIZE.  not regular or decorative  or corrosion resistant anodize, but HARD anodize.  It won't flake off nor gall when rubbing against aluminum.  7075 will take anodize readily and easily as does 6051.
   Bigiron
marvin Denny  AMA  499
Offline Russell Shaffer
« Reply #11 on: December 21, 2007, 09:10:24 PM »
OK, on the cheap guy track, would a brass sheet on the stock back plate be a good or bad idea?  Or is this whole thing a waste of time?  How many OLD very high time stock Foxes are out there anyhow? What wears out first on a stock, unmodified Fox 35?  I bet Bigiron knows. Not being a smartass, I am asking an honest question. I have a few old Fox engines and my gut feeling is to just run them as is.
Russell Shaffer
Klamath Falls, Oregon
« Reply #12 on: December 22, 2007, 10:41:39 AM »
  Yes, a brass sheet on the face of the current backplate will work .  If you attach it in some manner that will assure that it won't come loose, and also brass  will cause aluminum to corrode to some extent.  Stainless steel is better. but to work as the stuffer is intended, the thickness of the facing you put on should place the face to within 0.010 to 0.015  inch of the crank pin and also be attached such that it won't come loose nor leak (such as through loose rivits etc).
  There are TONS of older well used fox 29s and 35 out there and the 35 is still being made  (with the old style backplate).  What wears out first on a stock fox 35--- depends on how it is being used.  In racing (foxberg etc) with low oil content--- the crank pin.   In Stunt conditions with plenty of oil and good settings,  the shaft/bushing .  In any configuration  with a lean run using synthetic oil, the piston/cylinder assembly.
  What breaks?  in racing if pushed too hard  the rod.  If using a Heavy hub or other heavy rotating mass on the propellor  end,  the shaft.  If too much nitro and combined with a lean run,  the piston.
  how do I know---  GUESS.
  Bigiron
Offline Balsa Butcher
  • High Desert Flier
« Reply #13 on: December 22, 2007, 11:46:09 AM »
Reading this makes me think that the $14.25 cost of a stuffer backplate from Fox is a pretty good deal!
Pete Cunha
Sacramento CA.
AMA 57499
Offline Jim Oliver
« Reply #14 on: December 22, 2007, 01:20:11 PM »
Marvin, and other interested parties:
One of my buddies just tried to install a Fox stuffer back plate in a new Fox 35 which came from the factory with the new ceramic liner/piston set.  The piston would not go all the way to BDC with the stuffer back plate installed.
We "think" that the new piston skirt may be just a bit lower than the stock piston skirt, have't had time to do all the measuring just yet.
Stay tuned for future news!!
Jim
Jim Oliver
AMA 18475
« Reply #15 on: December 22, 2007, 02:13:24 PM »
  That is interesting Jim.  I just installed TWO in engines and one had interference and the other did not.  I will check this out.  Thanks for the heads up.
  Bigiron
« Reply #16 on: December 22, 2007, 02:33:10 PM »
Hi Mike
Sounds like a lot of trouble when you can buy one for 12.00  , but if you just wanna make it yourself and will not anodize it, use steel, you can make a very thin one from steel, which will work well on wear from the rod
Offline Steve Fitton
« Reply #17 on: December 22, 2007, 06:24:00 PM »
Geez, You give people from Jersey a bad name with that post!  Gluing a piece of tin to the backplate is seriously extending the limits of cheapness! n~
You need to be true to your ME degree and specify machining a new backplate out of titanium to correct the rod problem! >:D
Offline mike mullis
« Reply #18 on: December 22, 2007, 07:46:28 PM »
Hi Mike
well i reckon ya right about alot of trouble.....i was thinkin more along the lines of tinkerin..lol...  do all fox 35 have 3 bolt backplates? do you sell the backplates randy?? if so..how much to my door??  i have a fox engine that is supposed to be a 35 but it has a 4 bolt backplate...learnin bout the old foxes...have to excuse my stupid questions.....i bought it thinkin it was a 35...later i was told it was a fox 36???  reckon just what i got here??  lol...it looks to have a stuffer backplate i think...and the glow plug is in the head at an angle...any ideas?....can post pics i think...anyways thanks for all the help yall
« Reply #19 on: December 22, 2007, 08:16:26 PM »
  Mike, I hate to disagree with those other guys, but ite plate you want to attach to the face of the stock backplate needs to be a LOT thicker than tin-plate  ---like 0.030  to 0.045 inch in most cases.
  Tell you what'  give me a call tomorrow some time and we can discuss the stuffer at length.  I don't type too well.
   My phone # is  (316)838-8494  and I am in the central time zone.
    Marvin Denny
Offline Jim Thomerson
« Reply #20 on: December 23, 2007, 02:56:25 PM »
Fox 35's have a problem seldom discussed.  They are too light and you have add weight to make your airplane balance.  I do this with the not-recommended heavy hub.  So maybe there is a market for brass stuffer backplates? S?P
Offline Dick Fowler
« Reply #21 on: December 23, 2007, 05:06:24 PM »
I used to melt lead (solder actually) into the Fox backplate to add nose weight.
Dick Fowler AMA 144077
Kent, OH
« Reply #22 on: December 23, 2007, 05:44:59 PM »
   Mike, I missed this question the first time around.  sorry.  No ,All Fox 35s do not have three bolt backplates. Only the STUNT 35.  Fox put out many other 35s and 36s  that had (have) four bolt backplates.  The sport series of which there are at least four versiond all have four bolt backplates and some of them do give a pretty fair stunt run.  Then there is the 35 and 36 X series that have a square intake venturi as well as  the four bolt backplate..  I think most of us here was assuming (without fully comprehending your full question) that you were speaking of the Stunt 35.  As far as I know, there are no Stuffer Backplates for any other Fox engine than the three bolt backplate Stunt 35.
  Sorry for the overlook.
  Bigiron
