  • June 18, 2025, 05:55:16 PM
Author Topic: How tightly should a cylinder fit into a crankcase?  (Read 1113 times)
Offline frank mccune
« on: April 28, 2015, 09:23:07 AM »
     Hi:
     I just assembled a Fox .35 Stunt from assorted parts and I find that the cylinder is a shrink fit in the crankcase.  The piston is a very tight fit in the cylinder.  I used a p&c that I new was  great fit into a new crankcase. I cleaned all of the burned on residue from the outside of the cylinder to aid fitting it to the case.  I left the burned on castor residue on the piston.  Perhaps I should remove the p&c and remove the castor residue from the piston.  I left it on to help form a good seal. Perhaps, it should be removed as he fit of the p&c is vey tight. I have been running the engine in a rich mode hoping that it would form a good p&c fit.
     Any suggestions?
        Tia,
        Frank McCune
Re: How tightly should a cylinder fit into a crankcase?
« Reply #1 on: April 28, 2015, 01:01:31 PM »
None of the stunt 35s are a pressed fit, and all should be able to be installed with finger pressure, if it is tighter than that, look close to see why...
Offline Chris Wilson
« Reply #2 on: May 02, 2015, 05:36:42 PM »
Possible muffler clamp distortion going on here.
MAAA AUS 73427
