  • May 01, 2024, 07:54:01 PM
Author Topic: Fox .29 Stunt Wrist Pin  (Read 660 times)
« on: January 17, 2022, 10:51:36 AM »
   I have an ad over in the classifieds, looking for a Fox .29 Stunt wrist pin. This is the .29 that looks like a .35 Stunt with the triangular back plate. I know there was a later version of the .29 that was a whole different engine, but the wrist pin may be the same. If anyone knows this for sire and can supply correct part numbers for them that would be a great help on finding what I need. The wrist pin for the .29 Stunt is hollow and has brass eyelets in the ends because the .29 did not use retainer circlips for the wrist pin.
   Thanks a lot in advance!!
Re: Fox .29 Stunt Wrist Pin
« Reply #1 on: February 06, 2022, 02:20:37 PM »
Did you check with MECOA?
Best,   DennisT
« Reply #2 on: February 06, 2022, 02:49:14 PM »
Best,   DennisT
  I can't find a listing for it on the website. Back when they made this engine, they did part numbers way different. I may have to call them if I can't figure it out. I'm not sure when the stopped making the .29 Stunt. and I don't know if the later , bigger case .29 shared the same pin or not. I haven\t called primarily because i doubt anyone there would know!!
