  • July 06, 2025, 07:14:25 AM
Author Topic: Fox .25  (Read 2250 times)
Offline Joe Messinger
Fox .25
« on: May 22, 2010, 10:36:53 PM »
Well, here's another 'Fox" question(s) . . .
  I put together an S-1 Ringmaster last winter and the only engine I have that might be suitable for it is a Fox .25.  I did say "might be" because I know very little about the Fox .25 engines. This one is marked 'RC' on the case and has a bolt on c/l venturi.  No muffler or provision for one.   Here are my questions:
*Is the "Fox Burp" inherent to the .25 as it is with the .35 & .40 (perhaps others)?
*Is there a boost port and might blocking that (if it has one) help?
*Is the 'RC' ported differently from the standard c/l engines?
*Are there any other NVAs that will work on the .25?
*Would a 9/5 prop be suitable for this Ringmaster/Fox .25 set up?
  I don't have any ambition to compete with this Ringmaster, just try and have some fun sport flying with it.
  I'm sure an OS, LA .25 engine would be a much better choice for this plane but the Sterling kit and Fox .25 engine were given to me by a friend and I would like to be able to fly it, pretty much, as it was given to me.
Thanks for any advice and suggestions.
Joe
Joe Messinger
Offline Scott B. Riese
  • Just a student of stunt
Re: Fox .25
« Reply #1 on: May 22, 2010, 11:08:05 PM »
YES. But to reduece the burp lower the pitch and rev-up the engine
Yes..But I never tryed to block one before It's not a boost port it's a intake that needs to be smaller
NO the five I have are the same
YES...Any super tiger..HOWEVER you will need the venturi opened up and washers to fit the center of the hole
YES and 9.5x4.5 10x4
USE ALL CASTOR FUEL.
Scott Riese
Portland, Oregon
AMA 528301
Re: Fox .25
« Reply #2 on: May 23, 2010, 01:44:14 AM »
If its the light 70s one, vertical intake, two weeny screws ,
they work rather well .Little ribs below exhaust port ,
usually a bolt hole over and under cenre of exhaust .
and / or lugs fore and aft. Take a .35 silencer .
Theres a 19 the same but 1 fin lower , thats a howler
as the holes are the same size and the timings hotter.
Like Nitro , will switch / change tone . 9x4 if its lugging.
these are the one piece case ones.NOT the B.B. schnerule.
Offline Marvin Denny
Re: Fox .25
« Reply #3 on: May 23, 2010, 02:55:08 PM »
  If it is the Four bolt backplete, six bolt head, baffled piston, non-ball bearing shaft version with th verticle venturi/carb that Matthew seems to be referring to,, then it probably will not have the "Fox Burp" (none of mine did).  It already has a fairly small by-pass.  It does not 4-2-4 break easily, but runs well in a Rich two setting.  a 9 X 4 to 9 X 5 prop and up to 15% nitro with 25 to 30% CASTOR oil  should give you a pretty good run.
  Bigiron
marvin Denny  AMA  499
Offline dennis lipsett
Re: Fox .25
« Reply #4 on: May 23, 2010, 04:40:15 PM »
Don't cheat on the oil either. The Engines don't have pads on the wrist pin and have been known to scour a line on the liner if abused.
Dennis
Re: Fox .25
« Reply #5 on: May 25, 2010, 10:31:20 PM »
Thanks to all who answered my questions.
Marvin: Yes, the engine is the same as you described.
I'll install another NVA and give it a try.
Joe
Joe Messinger
Offline Bill Heher
  • Fix-it
Re: Fox .25
« Reply #6 on: June 08, 2010, 08:30:30 PM »
My flying buddy Tom has an S-1 ( average to slightly porky weight) with the 4 bolt  .25.  Stock except for a strap on lightweight tounge muffler.  10-4 wood  prop ( Zinger maybe?)
Good solid slightly rich 2- cycle run pulls the plane around on .015 X 60 with good tension and lap times around 5 secs.  No burp or funny run, stunts well and pretty easy to fly. It  seems to like a Fox Miracle plug with PowerMaster GMA 10% nitro all castor fuel.
Bill Heher
If it's broke Fix-it
Re: Fox .25
« Reply #7 on: June 09, 2010, 09:51:47 AM »
JOE...Hows the engine working now!!??
Scott Riese
Portland, Oregon
AMA 528301
Re: Fox .25
« Reply #8 on: June 09, 2010, 09:46:24 PM »
Scott,
Well, I haven't gotten around to changing the NVA on the Fox.25 yet or trying the engine/plane.  That project got sidelined due repairs being made on another plane. Unexpected encounter with a field box while landing resulted in a broken wing.  Proves field boxes are allot tougher than planes.  Of course field boxes don't fly so good although I felt like hurling the thing as far as I could after the incident.  Though better of it because I would then need to repair both the plane and the field box.
I hope to get the broken plane back in the air this week and will see what the Ringmaster/Fox.25 will do.
Joe
Joe Messinger
Re: Fox .25
« Reply #9 on: June 10, 2010, 10:56:50 AM »
When I was a kid my "field box" was my back pocket.  Now, I make sure to keep my field box at least six feet away from the expected flight line of the plane, and fetch what I need as I need it.
Of course, I'm flying with a bunch of old RC guys who want to stand right next to my field box, so there's more than the safety of the plane involved...
