  • June 20, 2025, 12:59:58 AM
Author Topic: Fox .19  (Read 3517 times)
Offline James Holford
Fox .19
« on: April 16, 2016, 03:47:22 PM »
I'm getting a fox .19 with an R/C carb.. I could wire it open but is it interchangeable for a C/L venturi?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #1 on: April 16, 2016, 10:51:16 PM »
James, is yours the .19 with the rectangular base carb? If you could get a pic up, it would be easier to help you identify the right parts.
Re: Fox .19
« Reply #2 on: April 17, 2016, 11:15:28 AM »
Dane it is practicallythe same one I got from you but with a R/C carb.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #3 on: April 17, 2016, 01:40:07 PM »
Cool, see if those interchange. If so, let me dig around and see if i have another fox venturi i can send you. I believe they are the same size up to a .25. Well, the base anyway
Re: Re: Fox .19
« Reply #4 on: April 17, 2016, 01:54:19 PM »
Cool deal.. I'll leave the one I got from ya as is. From the pics I got of the new to me one I'm getting... they look the like the same engine.
Jamie Holford
Lafayette, La
AMA #1126767
Re: Re: Fox .19
« Reply #5 on: April 17, 2016, 02:03:49 PM »
In fact ol Buddy I just order the Jr. Lightening Streak from Brodak... couldn't pass up that deal for 34$...  so may put the coming Fox.19 in it and the .19 from you in a Flying Clown from Brodak for some OTS fun :)
That's the plan anyways lol
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #6 on: April 17, 2016, 03:16:43 PM »
Oh... You mean this one! Lol. Great minds think alike i suppose. I just got this in the mail a couple days ago.
Re:
« Reply #7 on: April 17, 2016, 04:44:22 PM »
Yes sir!! That's the one! How's the wood.  By lucky chance is it Lazer cut :D:D
Jamie Holford
Lafayette, La
AMA #1126767
Re:
« Reply #8 on: April 17, 2016, 04:45:04 PM »
Is that a Ringmaster Triplane ?!?!?!?
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #9 on: April 17, 2016, 06:06:29 PM »
My assumption is that the wood selection is exceptional. I'll open the box in a little bit when i get home. I'm not sure about the cutting method.
And Yep! That's Pat King's Tri45 kit. It's a conversation starter any where i take it. Even all the RC guys at the field shut down operations to watch it fly. It's got a Magnum 52 four stroke on it.
Re:
« Reply #10 on: April 17, 2016, 07:26:16 PM »
Oh man that thing is sweet!!!!!!!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #11 on: April 20, 2016, 10:10:06 PM »
James, i keep failing to update you here, sorry.
I opened the box, and its die cut parts. The parts like the ribs will need to be cut out with your razor, but they are not crunched. The wood is really nice. I'll say it's good quality like a SIG akromaster, but the added benefit of having full size plans. Also, the lead outs complete kit is included. So i would say darn good money spent on this thing.
My plan is to build this as light as possible for a Cox td 09. Or medallion 09.
I've seen an akromaster on a fox 19 and it was awesome. This thing is like the same dimensions, well close. The akromaster is 34" at 250squares and this streak is 31" at 230 squares.
Re:
« Reply #12 on: April 21, 2016, 03:06:15 AM »
Oh yea buddy. Mine came in yesterday (3 days is all it took).  Went thru the kit quickly and kinda regret trading off my OS .10 now lol.  That fuselage is LIGHT!!  I think I may try to get a smaller engine for it or use the Enya .15 that I was gona put on the Akromaster and put the Fox .19 I got in yesterday as well on it. But will need to replace the Venturi as the needle is froze and when I try to adjust the entire carb spins around... big no no.
But overall I'm ready to start that Streak!!!!  It's so tiny!
Jamie Holford
Lafayette, La
AMA #1126767
Offline BillP
Re: Fox .19
« Reply #13 on: April 23, 2016, 11:48:55 AM »
Yep, same venturi as the Fox 25 cl bushing engine with 4 screw back plate.
Bill P.
Offline Dane Martin
  • heli pilot BHOR
Re: Fox .19
« Reply #14 on: April 24, 2016, 10:30:04 PM »
Thank you Bill.
James i looked through all my stuff... I even cleaned my room today! I can't find any fox parts to convert that for you. Sorry about that. But I'll keep an eye out for you.
Re: Fox .19
« Reply #15 on: April 25, 2016, 08:12:17 AM »
The 25 & 19 intakes ARE the same. even identical .
Found 6 or 7 turns on the needle for stunt on 10 or 20 % N . in zee twins .
Theres later retimed 19s & 25s with the steel prop driver , both with 1/4 propshafts .
