  • June 20, 2025, 06:44:57 PM
Author Topic: List YOUR Evo .60 set up  (Read 1018 times)
« on: September 01, 2012, 03:47:56 PM »
Venturi
Muffler
Prop
Fuel
glow plug
Thanks!
Offline Balsa Butcher
  • High Desert Flier
Re: List YOUR Evo .60 set up
« Reply #1 on: September 01, 2012, 04:51:12 PM »
My guess is that is the auction engine, Congrats on the win. Here's my set-up, it's been posted before but here it is again, probably a good starting point. Small stock venturi, Big Art tube muffler, RSM 12x5.5 prop,Powermaster 10% R/C fuel w/ 1 ounce aero oil, Merlin 2005 plug. I also installed a ST-NV, probably not necessary but since I had one, went with it. Fuel is critical, it doesn't like a lot of castor. RSM 5.5 ounce uniflow tank (no muffler pressure). 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: September 01, 2012, 05:24:32 PM »
Hi Pete,
Yep I did get the "auction" engine from Sparky, thanks!  Since I now have one, I am hoping to get those who have one chime in and we will "sticky" it to the top like the OS .46LA.  It is a lot easier to look in one spot than trying to search all the entries that mention any part of "Evo .60". ;D
Online Bill Hummel
« Reply #3 on: September 01, 2012, 05:32:03 PM »
Hi, Bill, very similar set-up listed above.  GREAT running stunt engine!  Like the RSM prop with this engine, too!
ama 72090
  • High Desert Flier
« Reply #4 on: November 17, 2012, 07:37:57 PM »
As an alternative to the RSM prop, try a ZOAR 12x6. They work great!  8)
Pete Cunha
Sacramento CA.
AMA 57499
