  • August 05, 2025, 05:18:36 AM
Author Topic: What venturi and NVA for Magnum XLS 15?  (Read 2108 times)
Offline Paul Wescott
« on: March 15, 2012, 01:29:07 PM »
Does anyone have suggestions for a venturi and NVA for a Magnum XLS 15 R/C version?   Is there a venturi for another brand that I can find on ebay?  NVA's can be found all over the place but which one?
RSM has a delrin venturi specifically for the Magnum XLS 15 but no NVA listed.
Thanks in advance!
Re: What venturi and NVA for Magnum XLS 15?
« Reply #1 on: March 15, 2012, 02:18:20 PM »
Thanks in advance!
Hi Paul
They have made several versions of the 15, there of course is no stock off the shelf setup for CL. I will check and see If I have one of these in stock and see what size it takes for you
« Reply #2 on: March 21, 2012, 12:53:47 PM »
I will check and see If I have one of these in stock and see what size it takes for you.  Randy
Randy, any good news?
Paul.
« Reply #3 on: March 21, 2012, 02:18:30 PM »
Paul.
Hi Paul
NOt yet, the magnum 15s I had here are not the newer Blue Head ones, I have ordered more of them to setup
I am sure I can setup the Venturie and NVAs for this motor for CL but I have to have one to get the sizes
