Engine basics => Engine set up tips => Topic started by: Paul Wescott on March 15, 2012, 01:29:07 PM
Does anyone have suggestions for a venturi and NVA for a Magnum XLS 15 R/C version? Is there a venturi for another brand that I can find on ebay? NVA's can be found all over the place but which one?
RSM has a delrin venturi specifically for the Magnum XLS 15 but no NVA listed.
Thanks in advance!
Thanks in advance!
Hi Paul
They have made several versions of the 15, there of course is no stock off the shelf setup for CL. I will check and see If I have one of these in stock and see what size it takes for you
I will check and see If I have one of these in stock and see what size it takes for you. Randy
Randy, any good news?
Paul.
Paul.
Hi Paul
NOt yet, the magnum 15s I had here are not the newer Blue Head ones, I have ordered more of them to setup
I am sure I can setup the Venturie and NVAs for this motor for CL but I have to have one to get the sizes
