  • June 17, 2025, 11:36:09 PM
Author Topic: Filler tube and over flow  (Read 753 times)
Offline Larry Wong
« on: January 02, 2020, 11:27:05 AM »
Is there any reason for putting the filling and over flow tubes on in board or out board side of plane?
Larry
Online Dave Hull
Re: Filler tube and over flow
« Reply #1 on: January 02, 2020, 02:31:15 PM »
The inboard side on a full fuse plane is traditional for several reasons:
1. Centrifugal force helps keep the fuel in, if needed. If you make sure the lines are above the tank level, then it should not siphon on the ground, but then when you fly inverted....
2. You want the vents in a high pressure zone. If you fly with any yaw at all, then on the outboard side, the air pressure will be lower.
3. If your engine is mounted inverted, then nearly all side exhaust engines will have the exhaust on the inboard side. This makes hooking up a pressure line, should you decide to try that, much more feasible.
There may be other reasons as well.
« Reply #2 on: January 04, 2020, 03:26:04 PM »
Larry,
As Dave said having the vents (uniflow or conventional) keeps the vents in the high pressure area. This is also the less turbulent and helps keep a consistent pressure into the tank and keeps the engine run more consistent. Some have put the vents out the top of the fuse and gotten it to work but the inboard side of the fuse is a safe bet. On profiles it is a little more important cause having them just off the tank can cause weird engine runs because of the turbulence coming off the fuse.
Best,   DennisT
« Reply #3 on: January 04, 2020, 07:07:24 PM »
If you had two vents venting outboard , youd get one syphoning
, at times .
