  • June 17, 2025, 05:06:34 PM
Author Topic: Blank  (Read 1790 times)
Online Rusty
Blank
« on: January 02, 2020, 07:09:10 AM »
Blank
« Last Edit: March 10, 2022, 11:09:35 PM by Air Master »
Re: OS 25 FX piston locks when head is tightened
« Reply #1 on: January 02, 2020, 07:50:05 AM »
Hello and Happy New Year....
I was wondering if anyone has any ideas of why the piston locks on my OS 25 FX when I tighten the head bolts.
*  The piston moves freely when the head is not tight.
*  The sleeve is seated in the block correctly.
*  I tightened in a cross pattern and tried tightening different areas first like on a Fox 35, but no help.
*  I have tried different connecting rods, same result.
*  I tried a head off another engine, no help.
*  I checked the block and sleeve mating surface for flashing, etc.  None found.
Russell Pieper
I have a 46FX that has a similar or perhaps the same problem.  Mine responds to the "Fox" method though and I can stop the "locking" with careful progressive tightening.  I have no way of figuring out the cause but, having been a machinist at one point in my life, I can venture a guess that something is not a perfect match at the cylinder/head joint.  I tried adding an extra head washer and it did not help.  Only tightening until it started locking then backing off till I found the bolt that caused it helped.  Engine runs fine once set.
One thing you might try is running all of the head bolts in as far as they will go and seeing if it is equal and more than would be required to seat the head.  Does it turn over smooth without the head?  There should be a slight "grab" at top dead center even without the head.  Mine will push the cylendar out of the case about 1/16" at TDC if it is dry.
« Last Edit: January 02, 2020, 08:13:32 AM by Ken Culbertson »
« Reply #2 on: January 02, 2020, 04:04:06 PM »
Russell Pieper
Rusty   there  are  many things that can cause this, if you have eliminated  some, I have seen this happen before, seems like you have something warped, and several occasions  I have seen engines like this, that may have a  pin to interlock the top of the sleeve, Some one  put the sleeve in and  tightened  down the  head, smashing the pin into the case, and warping the top of the  sleeve where it sits,  This maybe  something  you want to look at and  make sure  it is not the case with your  engine.  But make no mistake, if it is  free  until you tighten the head, chance  are very good  it is  warped
« Reply #3 on: January 02, 2020, 06:39:55 PM »
... The distance from the bolt seat on the head down to the top of the block is 5.75mm.  The bolt hole in the block is 10mm.  That means the bolt has a distance of 15.75mm, so a 12mm bolt isn't going to bottom out...
Unless the holes were threaded with a bottoming tap, the threads aren't good all the way to the bottom.  I don't know how OS usually does this job, but it would certainly be less expensive in a production environment to make the holes a bit deep and tap them with a normal taper tap.  That would leave several threads worth of taper at the bottom of the hole; screwing a screw tight into that would distort the block.
Take one of your 12mm screws and screw it in with your fingers until you feel some resistance, then measure the distance from the deck to the bottom of the screw.  If it's clearly going to tighten up the head with room to spare I'm full of gas and can safely be ignored.  If it's not distinctly smaller than the head thickness, you've got a problem.  If it's more than a mm taller than the head thickness, you've really got a problem.
« Reply #4 on: January 02, 2020, 07:34:09 PM »
We got this with a .46 sleeve in a 40 block , overbored . relieved the yop C'case bore for the bolt thread depth , a few thou.
As THE PIN may well be the CAUSE , a gentle whittle with a blade , adjacent . as per ' Scrapeing Bearings ' as once was the way .
Cripes , a file or wet & dry on a knife handle, if just at The pin . Lapping the top 1/4 inch, paper on a dowel , if whole diameter .
Incidently , Thought on the big Falcon Six , Id throw overlength H T Bolts in , for the Flywheel . As there was the depth threaded .
Allo , The Crank wont turn . ( this is on a well used engine ) Back the bolts out half way , By golly , she turns free ! . Double Check .
replace Std Short Bolts ! . As in the SWELL from the interaction causes binding. As you have well discovered .
« Reply #5 on: January 02, 2020, 09:33:11 PM »
Progress, but not solved.
It is the cylinder.   I took the cylinder out of a known good engine and put it in the engine I am working on.  Worked perfectly.
Also, I took the suspect cylinder and put it in the good engine and that engine locked up with I tightened the head bolts.
Now, what on earth can be wrong with the cylinder?
Did it get seriously overheated or get a load of wet stuff dumped on it when it was really hot?  Sounds like the cylinder is not round at the top.  A new cylinder might be in your future.
« Reply #6 on: January 02, 2020, 10:34:41 PM »
Feels kind of like we came in on the middle of this story--but you're still asking why this happened to you....
Did you buy the engine new? From a retailer? Or, was it from someone who may have taken it apart?
Had you run it before? Was it broken in? Did it run well, with at least a few hours on it?
Why did you take it apart? Because it would not turn over? (Or if it was new, why not send it back? Not trying to make a point here, just trying to figure out the history of the engine....)
Did the parts sit around? Maybe get bumped? A sleeve out of the engine can be pretty fragile. We're talking fits in the millionths of an inch here for a well-fitted piston/liner. On the plus side, the .25FX has got a decently thick liner.
One thing to watch out for is when you buy a new P/L and someone mails it to you in an envelope. May be bubblewrap or not. Very easy to eggshape the liner as it get the other packages dumped on top of it. When I get one shipped this way, it makes me cringe--and then I check to see if the fit has been damaged.
There's no common way of straightening a liner that I know of. Sure, you can measure, tap, and fiddle--but the odds of improving it are poor at best. And if you can't measure exactly the out of roundness to find the pinch spot, then you have virtually no chance at all.
The FX is a nice engine. Good luck with yours.
« Reply #7 on: January 03, 2020, 03:49:43 PM »
Hi,
I checked the bolts.  The bolts are 12mm long.  The distance from the bolt seat on the head down to the top of the block is 5.75mm.  The bolt hole in the block is 10mm.  That means the bolt has a distance of 15.75mm, so a 12mm bolt isn't going to bottom out.
Randy, you are correct.  I pushed the sleeve locator pin into the block so I could mark the land where the cylinder sits with a black marker and rotate the sleeve to see if it is seating evenly, which I found it was.   This did not cause the sleeve to stick. I have seen the locator pins pushed in before and it didn't cause this, but they were not FX engines either.    What can I do to check and correct?
HI
That will  not  tell  you that it is  OK , That may  tell you that  the top of the  case  is  OK, but not the  sleeve,  To see  for  sure  you would need  to check  the  run out, with a  dial indicator , of the  underneath part of the  sleeve  top
Sounds like  something  is  warped, so  I would just check everything  I could,  and  one thing  you could  also  check is  the  ROD , a warped  rod  will  also cause this
« Reply #8 on: January 03, 2020, 03:52:05 PM »
Dave,
I got the engine last Saturday at a swap for 10.00.  The engine looks to have very little time on it.  It was in a crash where the needle valve broke the backplate.  There was a bent fin on the non exhaust side of the CC.  The engine had been sitting a long time.  It was gummed up.  The crank was rusted pretty good.  The bearings were locked.   I cleaned the entire engine and including removing rust from crank and repolishing.  I replaced the bearings.
Guys,
I have gotten the piston to move pretty good when the head is tight now.  I noticed that the upper part of the piston about 1/32" is very shiny like that is where it is sticking, which is normal.   I decided with nothing to lose I would try something I never tried before.  I felt that maybe the sleeve is warped and when I tighten the bolts it is making it smaller and seizing it.   SO, I put the sleeve in the CC upside down where opposite pressure would be applied to the sleeve and put the block and sleeve in this configuration in the vice.  I tightened the vice to apply slight pressure on it.  I removed and reassembled.  It was a slight improvement.  So I did this 3 times and now it is  usable.  When the bolts are tight  the piston no longer seizes.    I'm not done yet as I will probably lap the piston some to get a perfect fit.   It has unbelievable compression.
I'm not going to put a FX back plate on.  I am going to use a FP back plate and a carb off a OS 28H engine.
I appreciate you guys discussing this.
PLEASE  do NOT  lap the  sleeve !  the  coating  is  much too  thin,  and  the  rod  could also be the  cause of this, along  with the  sleeve  being  warped
« Reply #9 on: January 04, 2020, 02:37:06 AM »
Air-ster,
Thanks for the engine history. That helps. Also good to know you don't have a boatload of bucks into this one already....
I didn't understand the way you assembled the parts inverted and squeezed in a vise. Did you simply rotate the sleeve in the case, squeeze, rotate, squeeze, etc.? I'd be real concerned that the sleeve might buckle around the ports, since there's a lot of meat removed there.
I've had a couple of discussions with guys about "compression."  Here are my basic thoughts:  Compression ratio is the fixed geometry of the engine. (Volumetric ratios.) An engine with a high CR may feel like it has more pop when you flip it--but only if the fits and seal was really good. Pinch would be the progressive tightening of the fit as you approach TDC. And, near the top the clearance may effectively go to zero. Binding could occur anywhere, and has little to do with "compression." In your case, the worry is that as the clearances get smaller at the top, a slight distortion is giving you binding, on top of any pinch, so not sure how you could accurately assess the seal at this point. (ie. "that the engine has a lot of compression.")
Something you might try is to put some kerosene or WD-40 in the exhaust port and turn it slowly thru TDC looking for bubbles. If you get a lot of leakage, and it turns pretty stiff at the top, then your current diagnosis of warped liner seem to be further validated.
Something you might try is to repeatedly heat cycle just the liner by itself in the oven. I might try a setting of 300F or 350F for 10 minutes, followed by an air cool, and then repeat 4-5 times. With aluminum, for example, it will relax partway back to the original shape. (We did this on certain critical aerospace parts to stabilize them prior to any final finishing.) I've never tried this on a liner--but for $10 you can risk learning something.
Since you're a parts swappin' kind of guy, did you try replacing only the head? If the original head had damage, that might tell you something.
Not sure anyone will ever have a junk barrel like Marvin. Made me think of McGee's closet--but bigger. Marvin's "barrel" must have been the size of one of those storage tanks at an oil refinery. Never heard of some part that somebody needed that wasn't in that barrel somewhere. It was legendary....
The Divot
Offline Oldenginerod
« Reply #10 on: January 04, 2020, 03:21:54 AM »
Hey guys, I'm pretty new to Stunthangar so I'm not sure of the etiquette, but I just wanted to share a story about a similar symptom I had with a MAX 15.
Hope I'm not seen as a "hyjacker" of this thread.
I got the 15 pretty cheap off an auction site.  It's the sleeved type, similar to an FP, not the earlier MAXIII steel fin.
When I first got it, all the screws were loose, with a couple of the head screws missing.  The backplate was also attached backwards/inside-out.  I mean, who does that?
Anyway, I pulled it apart, everything looked pretty good, so I ordered some genuine OS Allen head screws and assembled it up.  As with Russell's 25 FX, it turned over fine when the head was off, but got really tight when the head was screwed down.  Pulled it down again and looked a little closer, found that the rod had a very slight bend.  I had no issues straightening it out and looked to be no real harm done.  The problem actually became worse with the rod straight.  After much examination and head scratching, I noticed that as the piston rose in the cylinder, it actually rotated slightly, then rotated back as it descended.  Closer inspection revealed a bent crank pin.  I gave it to an engineer neighbour who examined it under a microscope and found the crank pin was cracked, not just bent.  Not sure why tightening the head caused the same issue as Russell's FX, but it did.  The greater mystery is, how did the previous owner manage to damage it like that?
To cut a long story short, after an extended period sitting in the parts drawer I managed to procure a good second hand crankshaft, installed it, and the engine now "feels" like a new one- Smooth, free and with excellent compression. Yet to give it a run.
Rod.
« Reply #11 on: January 04, 2020, 10:21:49 PM »
OldRod,
Welcome to the 'hanger.  Interesting story. On your engine, if the head wasn't dinged up; if the muffler/mounts aren't damaged; if the front of the crank was not dinged or bent, then I  might guess that your engine was hydro-locked and someone went after it with an electric starter. I wouldn't have expected a fracture at the crank pin, but as you say, something had to cause it....
Go run it and tell us how it holds up after an hour or so. Perspiring minds want to know....
The Divot
