Hello All:
Can anybody give me some advice about running a 25% castor oil and a 75% a alcohol mix in my engines.
I have used it in the past with no trouble but when the temperature dropped to about 50 degrees F, here in Pennsylvania, I experienced a drop in RPM when the battery was removed from the plug. I used this mix in Old Country in with no problems and flew in temps as low as -25F. My Fox and Enya engines would start and run on a typical Winter flying day when the temps were 0 degrees F.
In old country I used only Klotz oil as a lube. Perhaps this made the difference.
In any case, for sport flying, what plug is the best for no nitro fuel? What may I expect from running FAI fuel?
Perhaps I should just make a plan to purchase some nitro. Lol
Suggestions?
Tia,
Frank McCune
