  • June 15, 2025, 01:57:49 PM
Author Topic: repairing a stripped head bolt hole in an fp40  (Read 3318 times)
« on: December 05, 2015, 12:54:44 PM »
One of the head bolts in my fp40 is stripped. I want to ask before I assume the right thing to do. I'm thinking either bore and tap it for a 3.5mm bolt, or install a helicoil for the original 3mm bolt. The latter would be my preference. I don't know anything about thread pitch so I want to make sure I can get a bolt back in after fixing the hole. Any suggestions would be appreciated. Thanks.
Rusty
Offline rich gorrill
Re: repairing a stripped head bolt hole in an fp40
« Reply #1 on: December 05, 2015, 02:31:20 PM »
Hi Rusty, I'm assuming it's an allen head bolt that stripped? If so aren't small size easy outs available. Maybe a little heat, a little break oil and the easy out would be a viable way to go.
Rich
Offline bob whitney
« Reply #2 on: December 05, 2015, 03:45:56 PM »
 i assume u mean the case is stripped ,i would tap it out to the next bigger size bolt. not a fan of helicoils
rad racer
« Reply #3 on: December 05, 2015, 03:59:45 PM »
I'm going to tap it for a 4-40 since I don't have a metric tap. Thanks for the replies.
Rusty
« Reply #4 on: December 05, 2015, 05:10:11 PM »
Ewwww.
I'm not sure that there will be enough meat in the hole for a 4-40 tap to do much good -- you may just end up ruining the case completely.
'course, they're still available on eBay for not too much, so it may not be that bad of a deal.
« Reply #5 on: December 05, 2015, 05:57:39 PM »
I think there's enough, but I can look at it and tell before I foul it up.
« Reply #6 on: December 05, 2015, 06:40:02 PM »
You will need  tap for a 5-40 or a 3.5mm  a 4-40  will not work
Online Carl Cisneros
« Reply #7 on: December 05, 2015, 06:50:18 PM »
DO WHAT RANDY SAYS!!!!!!!!!!!!!!!!!!!!!!!!!
not enough meat there for a 4-40 tap to bite into.
ask me how I know,,,,,,,,,,,,,,,,,,,
Carl R Cisneros, Dist IV
Control Line RB
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: December 05, 2015, 08:12:08 PM »
Rusty, pm me your address
« Reply #9 on: December 05, 2015, 09:19:53 PM »
Dane, PM sent.
Randy, I know enough around here to pay attention to you on engines. I'll talk with my local engine man more about this before I proceed with the job. Thanks for your input.
I wish I had a 5-40 tap, I have plenty of black oxide hex bolts. I use them for deep reach prop bolts on my Cox engines.
Rusty
Offline Robert Zambelli
« Reply #10 on: December 05, 2015, 09:29:24 PM »
Rusty - I'm pretty sure I have a 5-40 tap if you need one.
For what it's worth, I have done quite a few heads with 4-40 helicoils and never had a problem.
« Reply #11 on: December 05, 2015, 10:13:37 PM »
Okay, thanks Bob. If you'll bring it next time we fly, I'll put this plane aside and finish the job at the field. What do I need for a drill bit, 3/32, 7/64, in that neighborhood?
Rusty
Offline Bill Johnson
« Reply #12 on: December 06, 2015, 11:09:16 AM »
Rusty
My helicoil chart shows a #31 or a 3mm drill bit for the hole size.
Best Regards,
AMA 350715
« Reply #13 on: December 06, 2015, 12:18:32 PM »
Bill, I just re-checked and that's about right. It was too late last night to be trying to think, when I posted my drill size guess. I was looking at the wrong row on the chart.
Thanks for the reply, I think I've got it from here.
To prevent my saying anything else dumb, I'm closing the thread.
Rusty
Sorry, this topic is locked. Only admins and moderators can reply.
