  • June 19, 2025, 04:24:44 PM
Author Topic: Enya 40xzs interchangeability?  (Read 936 times)
Offline rob biddle
« on: October 04, 2011, 05:35:46 PM »
  Hi Randy,
I was just wondering if the enya .40xzs was interchangeable with any other 35-40 size engines. In regards to shaft length, bolt pattern etc?
 Thanks in advance, Rob...
Robert Biddle
Offline Balsa Butcher
  • High Desert Flier
Re: Enya 40xzs interchangeability?
« Reply #1 on: October 04, 2011, 06:55:11 PM »
Well, I'm not Randy but I just checked and the 40 ZXS should be pretty much a straight drop in for the Aero-Tiger 36 which would also transfer to the TT 36 and Magnum engines. Length wise it is less than 1/64" longer than an Aero Tiger (2.88" vs 2.82" end of backplate to front of thrust washer) with identical mounting bolt pattern.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: October 04, 2011, 07:10:43 PM »
Hi all
Yes Pete is right  it will  fit where most of all the Heli based motors (28 to 39) fit. T Tiger , Magnum, Webra, OS etc.  it is also close to a FOX 35 that has a 1/2 inch prop shaft extention
Offline rob biddle
« Reply #3 on: October 05, 2011, 12:57:21 AM »
 Thanks guys,
Could be just the thing for a large or overweight fox powered model.
 Cheers, Rob...
Robert Biddle
