  • July 08, 2025, 01:37:27 AM
Author Topic: Evolution 36 C/L enigma - here we go again..  (Read 2543 times)
Offline Matt Piatkowski
« on: July 25, 2015, 06:21:33 PM »
Hello,
I thought the flight time problem with my Evolution 36 c/l engine was solved but this is not the case.
The engine-venturi-NVA-tank-prop-fuel-glow plug combination worked well for a while ( 7+ minutes flight times instead of 3 ) but two weeks ago the new problem appeared.
Specifically, the engine started quitting with the fuel still left in the tank.
Please see the details below - perhaps somebody experienced something so weird before.
Details:
Weather: 80 Deg. 60% humidity
Fuel: stock Omega, 10% nitro, no castor added. Did not use stock Omega, 15% nitro.
Prop: 11x4 Zinger
Lines: 60' eyelet to eyelet
Results:
1. Full tank of stock Omega 10% nitro ( 4.5 fl.oz ) burned to the last drop on the ground at 9,900 RPM.
Engine running time: 11 min. 25 s (!!) - run smoothly and very consistently, no RPM fluctuation.
Engine's head temperature immediately after the prop stopped: 289 deg.F
Let it cool for 15 minutes and the compression was completely back.
2. First flight - the same fuel and launch RPM like 1.
Flight time: 7 min 17 s. Plane landed with empty tank.
Engine's head temperature immediately after the plane stopped rolling: 221 deg.F.
3. Second flight - the same fuel and launch RPM like 1. and 2.
Flight time: 5 min. 07 s. Plane landed with some fuel in the tank.
Engine's head temperature immediately after the plane stopped rolling: 198 deg.F.
4. Third Flight - the same fuel and launch RPM like 1., 2. and 3.
Flight time: 3 min. 02 s. Plane landed with more than 50%  fuel in the tank.
Engine's head temperature immediately after the plane stopped rolling: 180 deg.F.
The plug used: OS Max Hot (6).
When I fly more, the flight times are decreasing and the engine quits with the fuel still in the tank.
Have you ever experienced something so weird?
No dirt in the fuel lines and fuel tank ( opened the tank already ), no dirt in the fuel filter, the plug goes bright orange while powered from the glow plug starter.
Any ideas what to check next?
Matt
Re: Evolution 36 C/L enigma - here we go again..
« Reply #1 on: July 25, 2015, 07:23:24 PM »
Clean out the needle valve body?? No mention of having done that.
Offline Bill Johnson
« Reply #2 on: July 25, 2015, 09:12:13 PM »
A prop with an imbalance causing fuel foaming, maybe?
Best Regards,
AMA 350715
Offline Dick Pacini
« Reply #3 on: July 25, 2015, 10:13:45 PM »
Having to wait 15 minutes to regain compression doesn't sound right.  That probably means the compression is dropping off in flight and that may account for the short run.  Have you tried a new plug?  Did you check the backplate for cracks or loose screws?
AMA 62221
Online Steve Helmick
« Reply #4 on: July 25, 2015, 11:11:43 PM »
Those don't have plastic backplates, do they? Might still shift & leak with heat, even if aluminum. Some say the Evo's don't like castor oil, but I'm not sure everyone agrees on that. I'd sure check all the screws and gaskets, including the glowplug. But I can't do it tonight, I've gotta get up early to go fishing in the morning!  ;D Steve
Offline Paul Allen
« Reply #5 on: July 26, 2015, 05:13:07 AM »
Matt
      Does it stop clean,ie instant shutoff,or lean out and stop.
In OZ
« Reply #6 on: July 26, 2015, 11:28:55 AM »
Everybody,
Just returned from the field with good news: the problem has been fixed by replacing the glow plug.
OS Max Hot #6 plug was simply dying. I have replaced it with the brand new Evolution medium plug and got five good and very consistent flights.
The flight time ( average of five ) : ~8 minutes with 10% Nitro Omega stock fuel, no extra castor added.
Launch RPM: 9,900 - 10,100, giving excellent lines ( 60 ' eyelet to eyelet)  tension overhead with 11x4 Zinger ( one flight: 9,900 RPM) and 11x4 APC Scimitar style prop.( four flights: 10,100 RPM).
Lap times: 5.2 - 5.3.
I consider the problem solved.
How to recognize that the glow plug is dying?
What are the indicators of it in order of importance?
What are the differences in appearance of the glow element of the dying plug and the healthy plug?
M
« Reply #7 on: August 06, 2015, 03:57:50 PM »
I have read about and experienced a glowplug that worked at the end of the season but didn't work at all or well next Spring. Oxidation or crust of some sort, I suppose. Choice of After-Run oil may be a huge part of the problem. Maybe apply oil without a glowplug or with a dead glowplug or at least an old and suspect glowplug? If you use fuel with a reasonable amount of castor and maybe some Aero-1, I don't think you need after-run oil. At least, mine are gummy when I go flying, and I don't use it except for long-term storage.
Silicon (Armorall) is thought to produce "taters" (lumps) on the glowplug element. Some say SIG fuel will produce "taters", but I seldom run SIG. I've never had any nasty surprises with Powermaster or Wildcat brands. Some put a new glowplug in every Spring, or even before every important contest. Pretty extravagant, IMO! But then, I always use Thunderbolt glowplugs or perhaps others made by Ohlsson Corporation. Good stuff!  y1 Steve
