  • June 18, 2025, 06:49:16 AM
Author Topic: Enya SS 30 with Nelson plug.  (Read 2634 times)
Offline Chris Wilson
« on: October 24, 2012, 11:24:19 PM »
Hi all,
         would the inclusion of a Nelson plug effect this engines stunt run?
I know zip about Nelson plugs except what I read on the net and am running on the assumption that they may be too cold.
Thanks.
MAAA AUS 73427
Offline GregArdill
Re: Enya SS 30 with Nelson plug.
« Reply #1 on: October 25, 2012, 02:47:57 AM »
Chris,
I'm pretty sure that particular engine was set up for Classic B TR. I doubt it'll do your typical 4-2 run, but if you're happy with 20K+ revs on a small prop you're in luck.
Haven't you got more suitable engines for your current project?
Greg
Offline Steve Thomas
« Reply #2 on: October 25, 2012, 08:11:01 AM »
Is this for your standard SS30 or that butchered one, Chris?
I don't know about Nelson plugs, but the engine will be very happy on something like an Enya #3 or an OS #8.
What is this current project?
« Reply #3 on: October 25, 2012, 03:31:26 PM »
Yes it is the B team race engine brought down a tad with a standard venturi and spray bar, muffler (that took quite a bit of tinkering to get to fit due to the standard muffler ears being ground off) and most likely a 9x4 prop up front.
Model, Steve's 'Miss BJ'  profile stunter.
Perhaps its a waste of a race orientated engine but what the heck!
MAAA AUS 73427
« Reply #4 on: October 25, 2012, 04:44:52 PM »
Chris, I'm not sure it would be a good combination as you describe it.  A standard SS30 will turn a 9x6 at close on 15000. That's about the smallest prop I'll use with it (for Plank racing, not stunt). With a 9x4 you'd be seeing, I dunno, 17000?   :o. Sure you wouldn't be running it peaked, but it still seems wrong!
I'd suggest trying the engine with a more suitable prop for the model. Depending on the extent of the TR mods, it might still work fine. If not, then your standard SS30 would be the way to go. With my SS30 Miss BJ, I've tried a Bolly 9.5x6, which works well and gives 5.0 sec laps, and an APC 10x4, which I like even better and laps slower. I'll try a 10.5x4.5 next time I take the thing out. The engine runs a very consistent wet 2. I've heard of people running a 4/2 with a 10x6 but I doubt it is using the engine to its best potential.
Cheers
« Reply #5 on: October 25, 2012, 07:24:27 PM »
Ok, Steve - 10x4 it is then.
I really don't envisage an issue with a breathed on engine if the venturi insert and exhaust and there to hold it back - its more the cold plug thingy that worries me but I suppose we will see.
Thanks.
MAAA AUS 73427
Offline Mike Greb
« Reply #6 on: October 25, 2012, 08:23:24 PM »
My big block nelson with tuned muffler is a bit picky on fuel with the nelson plug.  At a recent contest it would not hardly run on powermaster gma 10% 22 percent oil, but ran fine on Powermaster 10% 17 percent oil fuel.  I had similar problems on a 36 that I made from a os 40sx , my own crankshaft and ,full wave pipe and nelson plug, did not like sig fuel at all, and ran fine on Riches Brew.   Merlin makes some nelson type plugs, I will try them and see if those plugs are as picky.
« Reply #7 on: October 25, 2012, 10:38:50 PM »
Merlin plugs do indeed make a hot plug - thanks fro the tip!
MAAA AUS 73427
Offline GregArdill
« Reply #8 on: October 27, 2012, 02:06:03 AM »
Chris,
Why not run it the way it was built. 20% Nitro 20% Oil and run an 8X8 prop?
That way it'll not have problems fouling plugs and I guarantee your pulse will be elevated.  #^ #^ #^ #^
Greg
« Reply #9 on: October 28, 2012, 03:20:53 PM »
Chris,
Greg
But what about the compulsory use of a muffler though Greg?
The drama is that, sure it is was set up as a B class engine but I did not know that when I bought it!
And I have no use for that amount of heart start mate ........... unless someones else has a better use for it?
Bet that got ya thinking!
Cheers.
MAAA AUS 73427
« Reply #10 on: October 30, 2012, 09:09:29 PM »
The Nelson plug gives you more horsepower, regardless of what you use the motor for.  Typically it will give an extra 500-1000 rpm, or maybe turn a bigger prop without overheating.
If the motor has had extensive timing changes it will never give you a typical stunt run.  It'll have to run high rpm.  A small venturi helps restrict the speed the motor can pick up when it does lean out.  One set up I use on an LA 46 is a small enough venturi to limit the peak rpm to around 11,500, with the motor running at 10,500 or so in a 4 cycle.  When it leans out nothing drastic happens.
« Reply #11 on: October 30, 2012, 09:48:47 PM »
Hi Phi,
I believe that the engine has has the crank gas flowed, higher comp head, nelson plug and the muffler ears machined off but no actual timing changes.
All are reversible (in fact I has reversed all of it easily) except for the crank gas flow mods and I am assured by the seller that this will has minimal impact on lower rpm running.
Cheers.
MAAA AUS 73427
« Reply #12 on: November 01, 2012, 03:32:44 PM »
Filling in the front of the crank will only make it run better.  No worries there.
« Reply #13 on: November 06, 2012, 05:28:52 PM »
What about the spiral grinding of the crank web to increase gas flow?
On the face of it, it would seem to be of no detriment.
MAAA AUS 73427
Offline GregArdill
« Reply #14 on: November 07, 2012, 02:00:56 AM »
Chris,
You've asked all the questions, you've got all the opinions - NOW, Run the sucker!
Put a prop on it fuel in the tank and let it rip.
Bring it to Whalan on Saturday & I'll do it for you!
I'll even supply a newish 8X6 prop.
G
