  • June 17, 2025, 10:35:31 PM
Author Topic: How much fuel for ST46  (Read 1287 times)
steven yampolsky
« on: October 10, 2012, 08:26:57 PM »
How much fuel does a typical ST46 use? I'm trying to figure out how much of a fuel tank do I need. Is 4.5oz enough?
Re: How much fuel for ST46
« Reply #1 on: October 10, 2012, 09:56:07 PM »
I used 5.5 ounces in mine, as did many others, it will somewhat depend on plane size and how much power you will need
Offline Leo Mehl
« Reply #2 on: November 06, 2012, 11:48:48 AM »
I am using a 5.5s tank on my Vector and running a slow 2-4 break with an APC 11/6 prop and I have plenty of room for the pattern. It will also be about right for the 11/5. Good cobination but like the Stalker much better. HB~> HB~> HB~>
Offline Bill Hummel
« Reply #3 on: November 06, 2012, 02:03:34 PM »
Why, Leo?
ama 72090
« Reply #4 on: November 06, 2012, 03:26:46 PM »
   4.5 is just barely adequate for midwest summer, stock venturi, 5% nitro, and a good ring fit. Sea level, 10%, .173 venturi, and a good ring is something like 5.5. I have run configurations that were well up over 6 oz. I would suggest at least 6 and leave room for 7.
Offline Chris Wilson
« Reply #5 on: November 06, 2012, 05:24:25 PM »
Yep, I have friends that use 6oz in their Tigre 46's here in OZ and that is with drawing some out after fueling- so 7 oz does seem to be a realistic size.
MAAA AUS 73427
« Reply #6 on: November 06, 2012, 08:25:43 PM »
    Well, if you are going to try to compete with an ST46 today, you are likely going to need a lot of nitro (at least 15 and maybe 20), and that's going to take a lot of capacity.
