  • June 19, 2025, 04:59:11 PM
Author Topic: Head gasket needed  (Read 839 times)
Offline rich gorrill
Head gasket needed
« on: May 06, 2014, 02:49:17 PM »
Hello all, I,m trying to track down a head gasket for an o.s. 35FP. The engine bore is 20.2 mm, or .795 in. The bore for the 40FP IS 21.2 MM. does anyone know if the head gaskets for the 35 and the 40 are interchangeable? Any help would be much appreciated.
T.I.A., Rich
Re: Head gasket needed
« Reply #1 on: May 06, 2014, 06:28:53 PM »
I'd be checking the bores of Magnum and TT .36's. Chances are, they'd use a similar bore and also similar thickness, since most all those were designed by the same Japanese fella.  H^^ Steve
