  • July 07, 2025, 09:41:50 PM
Author Topic: Enya 61 side exhast conversion to rear exhaust  (Read 1720 times)
Offline Ivan Bolton
« on: January 25, 2013, 03:38:19 PM »
Can anyone  tell me if the the Enya 61CXLRS PRO uses the same piston and liner set as the Enya 61 CXRS Pro?
I cannot find parts listings for the motors and  I want to convert  my 61CXRS PRO side exhaust into a rear exhaust  61CXLRS PRO  by ordering  and fitting a rear exhaust case.  These  motors and spare parts are being manufactured again according to the En ya website http://www.enya-engine.com/ListCL_E.html
Offline Brian Hampton
Re: Enya 61 side exhast conversion to rear exhaust
« Reply #1 on: January 25, 2013, 07:01:01 PM »
Part #'s for the CXLRS are as follows;
Crankcase - 61CXLR03A
Liner - 61CXR04A
Piston - 61CXLR04B
Wrist pin - 61CX06
CL head button (low compression) - 61CXR0182
RC head button (high compression) - 61CXR0181
The piston may be different because of positioning of the ring locating pin and the wrist pin because an RE engine needs one end blanked off.
Offline Ivan Bolton
« Reply #2 on: January 28, 2013, 04:39:24 AM »
Brian.  You are correct about the piston being different.  I have heard from Ken Enya.  This is what he said:
If you would like to convert to 61CXLRS from 61CXRS,
you have to change
crank case, piston,
1 x crank case (without bearing)  (61CXLR03A) = JPY 4,700
or
1 x crank case (with bearing)  (61CXLR03) = JPY 6,450
and
1 x piston  (61CXLR04B) = JPY 2,400
I have now set about ordering the parts.
Thanks for the reply and detailed information  Brian.
« Reply #3 on: January 28, 2013, 09:34:03 AM »
No worries Ivan but check that your SE has a sealed wristpin or you'll lose crankcase compression out the exhaust.
Offline Chris Wilson
« Reply #4 on: January 28, 2013, 02:42:49 PM »
Plus the costs with the header and muffler.
Just wondering if the crankcase is made like the MVVS ones with 4 ports cast in them and then the liners rotates in 90º increments to line up for use with three of them.
This would leave a vestige of an unused transfer port under the exhaust port if true - and it would appear that way from pictures.
MAAA AUS 73427
« Reply #5 on: January 28, 2013, 02:57:42 PM »
No It is not made like the MVVS, Enya parts are unique to each version
« Reply #6 on: January 28, 2013, 03:15:28 PM »
Ah, so the cast shape under the exhaust that 'looks' like it should be hollow inside for a transfer port is simply left solid for the RE version.
Thanks.
MAAA AUS 73427
« Reply #7 on: January 28, 2013, 10:31:24 PM »
Thanks.
The top does not come off the case as the MVVS does, it is a 1 piece  case
Offline Steve Thomas
« Reply #8 on: January 28, 2013, 11:21:55 PM »
Do you currently have headers and mufflers for the 61RE, Randy?
« Reply #9 on: January 28, 2013, 11:57:31 PM »
Yes I think I have both Enya header and mufflers, and My header  and pipes
« Reply #10 on: January 29, 2013, 03:04:32 AM »
Thanks Randy, I'll send you an email.
« Reply #11 on: January 29, 2013, 07:15:37 PM »
This is Randy's header and muffler as fitted in my SV-11. The clamp is used to support the rear end and stop the muffler from sliding off the header. A piece of 1mm ply covers the tank compartment and shields the tank from exhaust heat. I don't use nitro so I made a new head button to raise compression from 8.8:1 to 12.4 which gave a lot more power. Actually the power rose by 26% which kind of surprised me :).
« Reply #12 on: January 29, 2013, 07:39:29 PM »
That looks fantastic Brian - kinda makes me want to order one!
MAAA AUS 73427
« Reply #13 on: January 31, 2013, 08:10:13 PM »
I also have the REAR EX  61 Enya  in stock, along with the Enya  header and muffler
