  • June 21, 2025, 04:27:01 AM
Author Topic: Enya 50 CX, what is it like for stunt use?  (Read 2810 times)
Offline Andrew Tinsley
« on: September 23, 2015, 10:52:30 AM »
The heading says it all. I have the opportunity to buy one and just wondered if I should.
Andrew.
BMFA Number 64862
Re: Enya 50 CX, what is it like for stunt use?
« Reply #1 on: September 23, 2015, 12:56:12 PM »
Great  engine   just needs a good  ring seal, performs  very well
« Reply #2 on: September 23, 2015, 08:22:27 PM »
Do the stock Enya engines run best as a 4-2-4 or rich 2-2-2? What prop and fuel?
Best,    DennisT
« Reply #3 on: September 23, 2015, 08:35:30 PM »
Best,    DennisT
Some will run 4-2-4  most all Enyas  will  run 2-2-2  or wet 2. The 50 will run a nice 4-2-4 or wet 2
It all depends on which Enya your talking about, the Enyas without  rings are  best!
« Last Edit: September 28, 2015, 11:34:20 PM by RandySmith »
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: September 23, 2015, 11:16:37 PM »
My SS50 (ringed) runs a great 4-2-4. with the power of a 60. Break in was much easier than on the iron piston Enyas (SS-40 and 45). Don't know if it is the same engine as the 50 CX though. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Martin Quartim
    • StuntHobby
« Reply #5 on: September 28, 2015, 06:32:20 PM »
The Enya 50CX is a true ABC engine.  Best used with a 12~12.5x3.75 3 Blade prop in 4-2-4 or 2-2-2.
Pick your favorite 60 size model like Thundergazer, Trivial Pursuit, Impact....and you will be impressed with the power and speed regulation this engine delivers, even without a pipe.
There is a lot of guys flying down here with Enya engines like this and they are all impressed with the power, reliability, durability  and speed control, even without pipe.
I will be glad to help you to set it up if you need help.
Martin
