Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 12, 2025, 03:39:16 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Enya 40xzs interchangeability?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Enya 40xzs interchangeability? (Read 962 times)
rob biddle
Trade Count:
0
Commander
on:
October 04, 2011, 05:35:46 PM »
Hi Randy,
I was just wondering if the enya .40xzs was interchangeable with any other 35-40 size engines. In regards to shaft length, bolt pattern etc?
Thanks in advance, Rob...
Logged
Robert Biddle
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Re: Enya 40xzs interchangeability?
Reply #1 on:
October 04, 2011, 06:55:11 PM »
Well, I'm not Randy but I just checked and the 40 ZXS should be pretty much a straight drop in for the Aero-Tiger 36 which would also transfer to the TT 36 and Magnum engines. Length wise it is less than 1/64" longer than an Aero Tiger (2.88" vs 2.82" end of backplate to front of thrust washer) with identical mounting bolt pattern.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #2 on:
October 04, 2011, 07:10:43 PM »
Hi all
Yes Pete is right it will fit where most of all the Heli based motors (28 to 39) fit. T Tiger , Magnum, Webra, OS etc. it is also close to a FOX 35 that has a 1/2 inch prop shaft extention
Logged
rob biddle
Trade Count:
0
Commander
Reply #3 on:
October 05, 2011, 12:57:21 AM »
Thanks guys,
Could be just the thing for a large or overweight fox powered model.
Cheers, Rob...
Logged
Robert Biddle
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
