  • July 07, 2025, 10:16:00 AM
Author Topic: Enya 40 xzs  (Read 913 times)
Offline Paul Allen
Enya 40 xzs
« on: April 21, 2008, 03:49:10 PM »
Guy's the Enya 40 XZS
What type of run? High rev's/low pitch or 2/4.
If any one has run one in a model,would they
share some info.
Randy if your there, do you know if they have
a large taper at the top of the liner.
Paul Allen
Re: Enya 40 xzs
« Reply #1 on: April 21, 2008, 04:04:35 PM »
share some info.
Paul Allen
HI Paul
The liner is tapered, I have not measured the taper so I don't know what you would call a large amount.
They are fit very well with what I would estimate is maybe 1.5 thou taper.  and they are fitted fairly tight.
The 40s are very well made and light motors, they put out very good power and run a strong 4 cycle
