  • July 13, 2025, 10:09:24 AM
Author Topic: Enya 40-50 size  (Read 1597 times)
Offline James Mills
Enya 40-50 size
« on: June 09, 2010, 09:58:31 PM »
Randy,
Do any of the Enyas comparable to the OS 46 fit the same beam width (between the motor mounts)?
James
AMA 491167
Re: Enya 40-50 size
« Reply #1 on: June 10, 2010, 08:55:15 AM »
Randy,
James
Which OS 46 are you asking about?
Offline James Mills
Re: Enya 40-50 size
« Reply #2 on: June 10, 2010, 05:08:33 PM »
Sorry, my bad.  OS LA 46.
James
AMA 491167
Offline Mike Scholtes
Re: Enya 40-50 size
« Reply #3 on: June 11, 2010, 01:24:51 PM »
I have the LA40/46 (same case) and an Enya 40XZS, the new stunt motor (smaller version of the new 61CX) and can tell you the mounting holes are quite different, if that is what you are asking. The Enya 40 does swap directly with a Magnum 36, if that helps. The larger Enyas appear to swap with larger Super Tiger engines (the 61CX is interchangable with ST51 for example).
Offline James Mills
Re: Enya 40-50 size
« Reply #4 on: June 11, 2010, 07:29:03 PM »
I'm wondering if it will fit in the same bearer as far as width is concerned.
James
AMA 491167
Offline Leo Mehl
Re: Enya 40-50 size
« Reply #5 on: July 13, 2010, 09:38:51 AM »
James
No- the Enya is wider.You may be able to shave a little off both sides of the bearers to get it to fit. I would be coutious about shaving too much off. H^^
Offline Damian_Sheehy
Re: Enya 40-50 size
« Reply #6 on: July 14, 2010, 06:36:45 PM »
James,
You can find the mounting specs for all Enya Control Line engines at their web site.
Just follow this link:
http://www.enya-engine.com/DimensionCL_E.html
Damian
